1 pagine (9 elementi)
Как написать скрипт - Messaggi
Собственно несколько вопросов, как:
1. Написать скрипт
2. Внутри тела скрипта использовать переменные Smath
3. Запускать скрипт по кнопке из exe представления Smath
Код на C# - примерный
С уважением!
1. Написать скрипт
using Kompas6API7;
using System.Runtime.InteropServices;
try
Kompas6API7.IApplication kompas = (_Application)Marshal.GetActiveObject("KOMPAS.Application.7"
IKompasDocument doc = kompas.App.Documents.Open("test", true, true);
IKompasDocument3D doc3D = kompas.App.ActiveDocument as IKompasDocument3D;
doc.Close(DocumentCloseOptions.kdDoNotSaveChanges);
doc3D.Close()
catch (Exception)
kompas = null;
kompas = null;
С уважением!
Hello [userlink]Kriss[/userlink],
It might worth the effort to take a look at the code of existing plugins in our SVN. Some of them:
File import/export/read/save:
- ExcelFileType, XMCDFileType, XlsxImportExport,DataExchange;
Communication between applications:
- XLSXupdate (this is written in VB.NET), Maxima;
Database:
- SQLite;
Database:
- SQLite;
Hello [userlink]Davide Carpi[/userlink]
Thanks for the reply.
I'll try workarounds,
if that happen I will try to put.
Arose fair question.
How to close the Preview window (*.exe file)
after clicking links
I guess it is the hyperlink region.
Alignment feature of hyperlinks is not available; I'll take a look on it when possible.
I'm not able to reproduce the 2nd issue, anyone else experienced this?
Hello Davide Carpi
I decided to use Smath Studio (Smath Viewer) as form to enter and calculate data.
The user then presses the Start button (as shown in the picture) and then start my program.
So I would like not to confuse the user and close the data entry form, ie Smath Viewer (executable file *.exe)
With best wishes
With best wishes
And another question
since You are a developer Hyperlink Region
It is possible to expand the possibilities of this Extensions:
Add command-line arguments when you start the program
For example:
"CalcMass.exe - ExchangeData.ods"
For example:
WroteHello Davide Carpi
With best wishes
Ah, ok!
Sometimes is not possible to close the viewer because internal exceptions, so I've thought about a bug.
I'll check if there is a safe way to kill the application within the hyperlink.
You can always add a text to ask the users that after clicking the link they can safely close the program.
WroteIt is possible to expand the possibilities of this Extensions:
For example:
You already can; right click on the region, choose "Flags..." from the context menu, and then add the arguments you need.
![2017-01-25 17_25_33-SMath Studio - [Page1_].png](/it-IT/files/Download/RmcZBg/2017-01-25-17_25_33-SMath-Studio---[Page1_].png)
![2017-01-25 17_21_08-SMath Studio - [Page1_].png](/it-IT/files/Download/CWX83k/2017-01-25-17_21_08-SMath-Studio---[Page1_].png)
![2017-01-25 17_24_10-SMath Studio - [Page1_].png](/it-IT/files/Download/YpWpQy/2017-01-25-17_24_10-SMath-Studio---[Page1_].png)
