equation solve problem
equation solve problem - Messaggi
#1 Pubblicato: 14/06/2023 21:12:21
soomoon
soomoon
1 apprezzamenti in 42 post.
i want to solve below problem
m, ka, pa
i try to solve this problem
but i can't get result.
20230614_lateral earth pressure.sm (100,47 KiB) scaricato 1422 volta(e).
Thanks in advance
#2 Pubblicato: 14/06/2023 22:48:20
Hi. Maybe the attached helps, but's hard to know. At the eqn 16 I count two open [ and only one closed ].
20230614_lateral earth pressure.sm (74,8 KiB) scaricato 1435 volta(e).
#3 Pubblicato: 15/06/2023 07:35:16
StvMath
StvMath
44 apprezzamenti e 1 disapprezzamenti in 76 post.
My suggested solution is in the attached.
LateralEarthPressure.sm (9,05 KiB) scaricato 1352 volta(e).
#4 Pubblicato: 15/06/2023 10:55:05
Get more accurate solutions from roots(,,,)
LateralEarthPressure.sm (13,13 KiB) scaricato 1386 volta(e).
#5 Pubblicato: 15/06/2023 23:28:49
Hi. Another way, plugin-less version. Have the advantage that can recognize the active and passive cases.
Click to enlarge
20230614_lateral earth pressure polyroots.sm (77,28 KiB) scaricato 1384 volta(e).
