SQLite Interface Plugin
SQLite Interface Plugin - A plugin that allows SMath Studio to interface the SQLite relational database engine - Messaggi
#41 Pubblicato: 17/09/2020 13:45:37
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Example
Updated.
Changes:
- now a scalar is returned for a matrix with one element;
- example changed;
- small improvements.
Davide Carpi 18/09/2020 09:43:00
#42 Pubblicato: 18/05/2021 12:30:27
Jason McCool
Jason McCool
9 apprezzamenti in 78 post.
I don't know if this is the right place to post this, but I think the issue I'm seeing is with the SQLite plugin. I compose a query based on some user input via combo boxes, concatenate all the parts together into a string, and then use the SQLiteQuery function to query the AISC Table database. This normally works well. Now, I get an error indicating that a "\" symbol is interfering. The database file location has that symbol, but I don't think that is the issue. When I look at the resulting string in SMath, it looks like correct syntax. But when I copy it into DB Browser, it shows all of the spaces and single quote marks in the query string translated as \0020\ and \0027\ respectively. If I manually replace those in DB Browser, the query runs as anticipated. Is there any way to get that corrected? I'm using SMath version 0.99.7786.
Thanks,
Jason
#43 Pubblicato: 18/05/2021 13:47:04
Gruppo: Moderator
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
sergio 18/05/2021 14:08:00, Jason McCool 18/05/2021 15:50:00
#44 Pubblicato: 18/05/2021 15:57:45
Jason McCool
Jason McCool
Thank you! That worked great. You rock!
Jason
