3D & Rotate Compendium
3D & Rotate Compendium - 3D & Rotate Compendium - Messaggi
#1 Pubblicato: 30/05/2017 10:22:20
Observe the non-commutative order M*rot [2D & 3D]
I don't like the rotation of the sphere ... welcome to doctor it !
Don't miss Paul W. rotate RGB image [far superior to Mathcad IMPROC !].
This compendium includes the 3 most used rotation system:
1. Euler [Roll, Pitch, Yaw]
2. Parametric [x,y,z,"t"]
3. Quaternion
Rotate KleinButtle.sm (17,23 KiB) scaricato 1406 volta(e).
Rotate Horn.sm (15,91 KiB) scaricato 1405 volta(e).
Rotate Meduse.sm (15,52 KiB) scaricato 1440 volta(e).
Rotate Parametric [t, xyz].sm (12,15 KiB) scaricato 1174 volta(e).
Rotate Breather [Quaternion].sm (268,5 KiB) scaricato 1238 volta(e).
Rotate Image RGB.sm (348,63 KiB) scaricato 1436 volta(e).
Rotate Breather Water Mill.sm (998,24 KiB) scaricato 1526 volta(e).
Rotate Breather [4 Orientations].sm (1000,43 KiB) scaricato 1226 volta(e).
Rotate Sphere.sm (1,67 MiB) scaricato 1501 volta(e).
#2 Pubblicato: 30/05/2017 14:00:58
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
For expressiveness, I sometimes change the foreshortening
Rotate Breather Water MillMod.sm (1002,46 KiB) scaricato 1491 volta(e).
#3 Pubblicato: 30/05/2017 15:30:07
... earth rotate, doctored.
Rotate Sphere Poles.sm (14,24 KiB) scaricato 1457 volta(e).
#4 Pubblicato: 30/05/2017 15:42:09
Hello Ber7 !
I can see what you are trying to do ... let me find "Wind Mill" equations,
if they exist ?
Cheers, Jean
#5 Pubblicato: 30/05/2017 18:55:07
... here is the Strumpf wind mill
Rotate Trifolium.sm (19,11 KiB) scaricato 1429 volta(e).
