1 pagine (9 elementi)
how to plot discrete function - Messaggi
hi,
I am trying to create a sheet to design welds and want to plot the geometry of the weld lines.
the problem is if I assign a matrix with x,y coordinates the 2D plot will draw a continuous function connecting all points, and when I assign this to a discrete matrix of line coordinates it does not plot unless I assign each line individually which is bad as I want it plotted based on the geometry.
in the example below, I want the 2D plot to plot LW without manually adding each component of LW individually.
Thanks
Thanks
sergio 08/11/2022 15:53:00
Many thanks, alyles!!
WroteI want the 2D plot to plot LW without manually adding each component of LW individually.
... it may be possible to make svg [Scale Vector Graphic].
test_alyles & jean.sm (41,37 KiB) scaricato 1276 volta(e).
... here is the project as offered.
Utilities Discrete COMPANION_2 WELD.sm (20,2 KiB) scaricato 1314 volta(e).
4 utenti hanno apprezzato questo post
sergio 09/11/2022 07:36:00, NDTM Amarasekera 09/11/2022 09:42:00, Arie 09/11/2022 09:42:00, Alvaro 09/11/2022 18:32:00
WroteYou might consider building geometry plots from the pre-defined objects in the XY-Plot-plugin. ...
And maybe you may be interested in this other Martin' post, if you want to draw steel profiles to be welded, and by the way calculate their mechanical parameters: https://en.smath.com/forum/yaf_postsm78221_Split-Areas-Polygons-convex-and-concave--by-lines.aspx#post78221
