Unified Soil Classification System USCS
Unified Soil Classification System USCS - spreadsheet - Messaggi
#1 Pubblicato: 31/08/2023 16:30:44
Fabian Valencia Villaquiran
5 apprezzamenti in 3 post.
Attached is a spreadsheet to classify the soil according to USCS and the granulometric curve is plotted by sieving.
Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions.
This is the original code.
USCS1.sm (101,6 KiB) scaricato 1855 volta(e).
This is the original code with another particle-size distribution
USCS.sm (103,17 KiB) scaricato 2245 volta(e).
Below in another post it is updated with a better presentation of the granulometric curve.
João Felipe Seráfico Melo 31/08/2023 23:41:00, Alvaro 01/09/2023 01:11:00, sergio 01/09/2023 05:03:00
#2 Pubblicato: 06/09/2023 10:14:07
Fit & explorer ... Jean
USCS fit Granulometry.sm (21,61 KiB) scaricato 1779 volta(e).
#3 Pubblicato: 07/09/2023 01:23:17
Thank you so much,
I added the logistic sigmoid function you made to the initial code and it compare with and without the fit. In addition to the initial curve, I graphed it using the Zed Graph, where it can be better appreciated using a semilogx graph
USCS-fit-Granulometry.sm (175,97 KiB) scaricato 1674 volta(e).
#4 Pubblicato: 08/09/2023 15:07:51
Thank you so much,
Thanks as well, very educative.
A large suite of math codes added
Project USCS fit Granulometry.sm (90,24 KiB) scaricato 1782 volta(e).
