Smath issue with exp as matrix - Messaggi
You can replicate in SMath what the Maxima engine does with the vecotrize() function (otherwise by default SMath tries to perform a scalar operation and fails).
![2024-12-24 18_36_34-SMath Solver - [test.sm_].png](/it-IT/files/Download/EbsXgC/2024-12-24-18_36_34-SMath-Solver---[test.sm_].png)
WroteBut still the SMath result is not the same as the Mathcad result...
I think it's because as Davide said, Matrix exponential is not implemented in SMath. But then how to calculate the Matrix exponential in SMath? There is a way somehow?
In general, the other CASs have special functions for this extension of the exponential function: expm in matlab, MatrixExp in wolfram mathematica, exponential in maple and matrixexp in maxima, which you can access from SMath:
mat-exp.sm (13,45 KiB) scaricato 1688 volta(e).
So I guess if it is right for the developers of maxima, maple, mathematica and matlab to distinguish between both functions and to have specific instructions for each of them, then doing so in SMath is right, regardless of what the developers of mathcad think.
WroteHi Cornel. The exponential function is a well-defined function from the complex plane into the complex plane. A possible extension to its domain and range being square matrices analogous to the ordinary exponential function can be defined as e^A = sum(A^k, k=1...infinity). And notice that this is valid only for square matrices, not for the general case.
Ok, understood. This was the thing I was looking for. Thank You.
WroteIn general, the other CASs have special functions for this extension of the exponential function: expm in matlab, MatrixExp in wolfram mathematica, exponential in maple and matrixexp in maxima, which you can access from SMath:
It seems there is also MatrixExponential in newer maple versions.
I tried to solve this problem using maple plugin by its library with(LinearAlgebra) command in maple, but couldn't prevail.
Old LinearAlgebra library lacks this particular command. Then you posted this solution.
WroteIt's possible, but not as part of a plugin. I don't use maple often, so I'm too lazy to spend time on it.
But how to use then the latest maple engine If it's possible?
From my point of view If someone can make possible to use every time the latest version of maple engine in SMath then it would rise a lot SMath
And If You dont use often maple 6, then what you use? Maxima?
See below:
https://writings.stephenwolfram.com/2019/05/launching-today-free-wolfram-engine-for-developers/
And this wolfram engine for developers it's updated as latest wolfram mathematica engine, even though the article is from 2019
