Polyroots bad answer
Polyroots bad answer - roots of cubic equation gives wrong answer - Messaggi
#1 Pubblicato: 17/07/2012 02:54:33
litus321pr
litus321pr
0 apprezzamenti in 5 post.
When calculing roots of x^3-x^2-x+1 using polyroots gives wrong answer.
polyroots bug
#2 Pubblicato: 17/07/2012 06:55:13
Gruppo: Moderator
Why do you consider the result obtained by polyroots() to be wrong?
As we all know, cubic polynomial has three roots. You get them [-1,1,1] using polyroots(), although by ignoring the imaginary parts which are quite small and you could ignore them. The small imaginary parts might be due to the numerical procedure used to obtain the roots.
If we are in doubt about real or complex roots then Descartes' rule of signs could help us out.
#3 Pubblicato: 18/07/2012 03:04:29
litus321pr
litus321pr
Thank you for your quick comment, but I think that when you see complex numbers in the roots of the polynomial it may mislead you in the correctness of the solution. Honestly when I counter check with ti-89 it gave me complex roots too, but in a friend Hp 50g gave me correct roots {1,1,-1}. You are correct the algorithm used appears to be companion matrix.
