1 pagine (2 elementi)
Mono Package Running Under aarch64 Linux - Messaggi
Host machine
Previously running SMathStudioDesktop.1_1_8763.Mono with no problems updated to SMathStudioDesktop.1_3_0_9126.Mono; the app launches & the text seems invisible. Also 10% launches sometimes fail
I was able to correct font bug by **
Even normal launches throw these errors
OS: Armbian 24.11.3 noble aarch64
Host: Rockchip RK3566 OPi 3B
Kernel: 6.1.75-vendor-rk35xx
Packages: 2196 (dpkg)
Shell: bash 5.2.21
Resolution: 1920x1080
DE: GNOME 46.0
WM: Mutter
WM Theme: Adwaita
Theme: Adwaita [GTK2/3]
Icons: Numix-Circle [GTK2/3]
Terminal: gnome-terminal
CPU: (4) @ 1.800GHz
Memory: 1900MiB / 3919MiB
./smathstudio_desktop_mono
double free or corruption (fasttop)
Native Crash Reporting
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Native stacktrace:
0xaaaac3701970 - mono : (null)
0xaaaac342fb28 - mono : (null)
0xaaaac3456184 - mono : (null)
0xffff986d57b0 - linux-vdso.so.1 : __kernel_rt_sigreturn
0xffff98497628 - /lib/aarch64-linux-gnu/libc.so.6 : (null)
0xffff9844cb3c - /lib/aarch64-linux-gnu/libc.so.6 : gsignal
0xffff98437e00 - /lib/aarch64-linux-gnu/libc.so.6 : abort
0xffff9848abf0 - /lib/aarch64-linux-gnu/libc.so.6 : (null)
0xffff984a212c - /lib/aarch64-linux-gnu/libc.so.6 : (null)
0xffff984a447c - /lib/aarch64-linux-gnu/libc.so.6 : (null)
0xffff984a6fa8 - /lib/aarch64-linux-gnu/libc.so.6 : __libc_free
0xffff94299b6c - /lib/aarch64-linux-gnu/libglib-2.0.so.0 : (null)
0xffff8fb7fa44 - /lib/aarch64-linux-gnu/libpangoft2-1.0.so.0 : (null)
0xffff94480478 - /lib/aarch64-linux-gnu/libpango-1.0.so.0 : (null)
0xffff94495df8 - /lib/aarch64-linux-gnu/libpango-1.0.so.0 : (null)
0xffff9448ae68 - /lib/aarch64-linux-gnu/libpango-1.0.so.0 : (null)
0xffff9448ee80 - /lib/aarch64-linux-gnu/libpango-1.0.so.0 : pango_layout_get_pixel_extents
0xffff9456bc9c - /usr/lib/libgdiplus.so.0 : gdip_pango_setup_layout
0xffff9456c4a0 - /usr/lib/libgdiplus.so.0 : (null)
0xffff8d48d7f8 - Unknown
Telemetry Dumper:
Pkilling 0xffff986cf020 from 0xffff8d6df160
Pkilling 0xffff9586f160 from 0xffff8d6df160
Entering thread summarizer pause from 0xffff8d6df160
Finished thread summarizer pause from 0xffff8d6df160.
Waiting for dumping threads to resume
External Debugger Dump:
mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb
Basic Fault Address Reporting
Memory around native instruction pointer (0xffff98497628):0xffff98497618 e2 03 15 aa 00 7c 40 93 68 10 80 d2 01 00 00 d4 .....|@.h.......
0xffff98497628 1f 04 40 31 e0 97 80 5a df ff ff 17 e0 03 16 aa ..@1...Z........
0xffff98497638 e2 ea ff 97 d4 ff ff 17 e0 03 16 aa 9f ea ff 97 ................
0xffff98497648 ca ff ff 17 f7 23 00 f9 c0 c6 01 94 fd 7b bf a9 .....#.......{..
Managed Stacktrace:
at <unknown> <0xffffffff>
at System.Drawing.GDIPlus:GdipMeasureString <0x00017>
at System.Drawing.Graphics:GdipMeasureString <0x000d7>
at System.Drawing.Graphics:MeasureString <0x00083>
at System.Drawing.Graphics:MeasureString <0x0004f>
at System.Drawing.Graphics:MeasureString <0x000bb>
at System.Windows.Forms.XplatUIX11:GetAutoScaleSize <0x00063>
at System.Windows.Forms.XplatUI:GetAutoScaleSize <0x00037>
at System.Windows.Forms.Form:GetAutoScaleSize <0x0001b>
at System.Windows.Forms.Form:.ctor <0x000ef>
at SMath.UI.Accessories.SplashScreen:.ctor <0x0001b>
at SMath.UI.Accessories.SplashScreen:.ctor <0x0004b>
at SMath.UI.Accessories.SplashScreen: <0x00073>
at System.Threading.ThreadHelper:ThreadStart_Context <0x00103>
at System.Threading.ExecutionContext:RunInternal <0x00193>
at System.Threading.ExecutionContext:Run <0x0002b>
at System.Threading.ExecutionContext:Run <0x00053>
at System.Threading.ThreadHelper:ThreadStart <0x0006f>
at <Module>:runtime_invoke_void__this___object <0x000f3>
Aborted
sudo apt install -y fonts-arkpandora
(mono:7033): GLib-WARNING **: 05:54:23.915: corrupted double-linked list detected
(mono:7033): GLib-WARNING **: 05:54:30.715: corrupted double-linked list detected
Its getting extremely random, sometimes it doesnt start, sometimes OK, sometimes launch is OK fonts are garbled & or invisible
I have installed official Ubuntu packages libfreetype & dejavu-* packages
Additionally I renamed previous SMath folder in ~/.config but to no avail
(mono:7201): Pango-WARNING **: 16:28:55.197: failed to create cairo scaled font, expect ugly output. the offending font is 'DejaVu Sans 8.25'
(mono:7201): Pango-WARNING **: 16:28:55.198: font_face status is: no error has occurred
(mono:7201): Pango-WARNING **: 16:28:55.198: scaled_font status is: error occurred in libfreetype
- Nuovi post
- Nessun nuovo post
