1 pagine (7 elementi)
mindmapping and Smath - Messaggi
Hi, is there any way to create mindmaps inside Smath, or to link specific to smath items (graphs, matrices, ...) from other files?
I know i can link to mindmap files, but i think it's more useful and coherent to link mindmap topics to Smath items.
Otherwise that would be an idea for a plugin.
There isn't any baked solution but if the data file is stored in json data format, an idea might be to use the script region to read/write the data and the modeler region to manage the graphs.
WroteThere isn't any baked solution but if the data file is stored in json data format, an idea might be to use the script region to read/write the data and the modeler region to manage the graphs.
Thanks Davide, but I don't get a taste for the Modeller plugin. If possible I'd prefer to use a wrapper plugin for Activex objects, and embed a Graphviz, or Freemind, Activex plugin into Smath. Is that possible? (wrapping ActiveX objects). I could not find a full developer's reference, so i do not know how a "graphical plugin" is created. And I'm not a developer, but I know you are.
Greetings,
For what it may be worth, I did try to research/develop a wrapping an ActiveX object into SMath and I was not successful. While I am inexperienced in creating a wrapper, I think the main reason I was unsuccessful was due to ActiveX being phased out.
For me, it makes more sense to recreate the controls I want from scratch, then to figure out how to successfully wrap controls that Microsoft does not want users to use.
With at being said, if anybody was able to figure out how to support ActiveX objects within a Region, I would still be interested; its just that I'm giving up on this endeavor.
-Kenny Lemens, P.E. ᵂᴵ
Do you have a 4 year old logic?
You saw word tree in definition of mindmap.
Then your twisted mind worked this way;
Mindmaps can have tree structure, trees are fractal in nature.
Mindmaps are fractal.
Chili pepper is hot, sun is hot. Chili pepper is sun.
1 utenti hanno apprezzato questo post
fedeghi 06/12/2022 03:55:00
Logic diagrams are good examples of Mind Map.
Was done in Mathcad/Mathsoft 11.
- Nuovi post
- Nessun nuovo post
