X-Y Plot Region
X-Y Plot Region - Extends SMath Studio with a X-Y Plot Region. - Messaggi
#1 Pubblicato: 26/04/2013 09:20:32
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
X-Y Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
2018-12-21_13-32-23.png 2018-09-24_12-55-34.png XYPlot. Examples.png 2018-12-22_16-15-43.png 2018-08-03_08-25-36.png 2018-10-01_17-51-54.png 2021-11-17_00-50-10.png 2021-11-17_00-50-29.png
XYPlot. Examples.sm (30,04 KiB) scaricato 3988 volta(e).
XYPlot. Examples.pdf (154,55 KiB) scaricato 2983 volta(e).
XYPlot. Demo.sm (5,5 KiB) scaricato 2953 volta(e).
XYPlot. Demo.pdf (45,63 KiB) scaricato 2235 volta(e).
XYPlot. Text labels.sm (10,1 KiB) scaricato 2953 volta(e).
XYPlot. Text labels.pdf (53,78 KiB) scaricato 1917 volta(e).
XYPlot. Fill area.sm (10,03 KiB) scaricato 2736 volta(e).
XYPlot. Fill area.pdf (84,35 KiB) scaricato 1671 volta(e).
XYPlot. Draw shapes.sm (19,85 KiB) scaricato 3278 volta(e).
XYPlot. Draw shapes.pdf (92,91 KiB) scaricato 2285 volta(e).
XYPlot. Linear polar.sm (56,78 KiB) scaricato 2622 volta(e).
XYPlot. Linear polar.pdf (134,78 KiB) scaricato 1646 volta(e).
3D plots in XY Plot plugin
pMesh.sm (244,1 KiB) scaricato 2701 volta(e).
pMesh.pdf (3,04 MiB) scaricato 2088 volta(e).
Functions for grids, meshes and plot surfaces. Support triangular meshes and multiple surfaces in the same plot.
pSurf.sm (315,64 KiB) scaricato 2432 volta(e).
pSurf.pdf (2,2 MiB) scaricato 1824 volta(e).
Small piece of code for filled 2-D contour plot in the XY plot plugin.
FillContour.sm (34,45 KiB) scaricato 2489 volta(e).
FillContour.pdf (306,44 KiB) scaricato 1782 volta(e).
Note: '~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot.
Click to enlarge Click to enlarge Click to enlarge
XYPlot.%20Parametric.sm
Links:
1. Dr. Xu's Books .
2. Creating charts & graphics without coding .
17 utenti hanno apprezzato questo post
Oscar Campo 26/04/2013 09:38:00, frapuano 03/12/2016 09:11:00, Mark R Harris 29/08/2022 07:50:00, sergio 13/01/2024 04:42:00, Radovan Omorjan 26/04/2013 10:32:00, Infinity 29/04/2013 03:12:00, ioan92 25/05/2025 13:21:50, ruddy 24/09/2025 00:30:07, Valery Ochkov 29/10/2025 15:15:21, Fridel Selitsky 26/04/2013 10:29:00, Davide Carpi 26/04/2013 10:12:00, Martin Kraska 26/04/2013 09:39:00, IVR 13/07/2013 05:09:00, yajurito 11/12/2017 17:33:00, Andrey Ivashov 22/09/2021 08:49:00, zoom 17/01/2016 17:14:00, maria 02/05/2025 03:56:13
#2 Pubblicato: 26/04/2013 09:38:29
1.361 apprezzamenti in 2.275 post.
Gruppo: Moderator
Здорово!
I tried some functions (typed to the placeholder):
x - nothing happens
sin(x) - works
ln(x) - crash (perhaps due to undefined values)
any undefined function - crash
previously defined function returning a list - GUI freeze
#3 Pubblicato: 26/04/2013 10:23:34
1.443 apprezzamenti in 2.936 post.
Gruppo: Moderator
Nice work uni
You can change only the function for now. Need to figure out a way how to pass parameters to display the graph or do it like in Mathcad.
A way could be to use context menu items (see ConstructorRegion plugin by Andrey)... also the Mathcad mode it's quite interesting...
you can post the plugin code?
#4 Pubblicato: 26/04/2013 10:46:39
325 apprezzamenti e 1 disapprezzamenti in 2.052 post.
Gruppo: Moderator
This is a long time waiting feature and I think we are all excited about it
Good luck uni
EDIT: I tried it a bit in a "faulty" Mono in Xubuntu. It si working initially although with crashes as Martin mentioned
#5 Pubblicato: 26/04/2013 10:47:33
Gruppo: Moderator
The code is taken from this book:
C# Application Series - Xu J. - Practical C# Charts and Graphics [2007, PDF, ENG] (link, rus).
I have something removed and added something to get the plugin. I added sources.
mkraska, not so fast Try some number.
2 utenti hanno apprezzato questo post
Davide Carpi 26/04/2013 10:52:00, ioan92 22/07/2013 05:38:00
#6 Pubblicato: 26/04/2013 11:02:04
Gruppo: Moderator
Thank you very much both for the sources and the book
[EDIT] plugins on wiki updated
#7 Pubblicato: 26/04/2013 11:45:46
kilele
kilele
134 apprezzamenti in 397 post.
Gruppo: User
thank you very much uni!
please look at this post:
http://en.smath.info/forum/yaf_postsm9105_Plots-improvements.aspx#post9105
ZedGraph is c# targeting .net20 so it should work both in windows and linux.
#8 Pubblicato: 26/04/2013 11:56:51
Basile
Basile
8 apprezzamenti in 172 post.
Gruppo: User
Thank you uni.
This is long overdue.
As you develop it, please have in mind the basic form of axes: Lin-Lin, Lin-Log, Log-Log.
Basile
#9 Pubblicato: 26/04/2013 12:45:04
Gruppo: Moderator
...Try some number.
#10 Pubblicato: 26/04/2013 15:22:17
Basile
Basile
Gruppo: User
Radovan,
How did you put graph title and axis titles? and axes greater than 1.
Thank you,
Basile
#11 Pubblicato: 26/04/2013 15:58:45
Gruppo: Moderator
Updated. Form formatting is added to the context menu. Changes take effect after the recalculation. You can use system for several functions but be careful (not tested yet).
Davide Carpi 26/04/2013 17:09:00, Radovan Omorjan 26/04/2013 17:01:00
#12 Pubblicato: 26/04/2013 16:39:18
Gruppo: Moderator
Hello Basile
I did nothing else just put a number in the function placeholder, as uni said. It seems that uni just put this example just as a test at the moment.
Lots of user feedback in quite a short time shows that we are very interested in this plugin. It seems that we need to have some more patience until the very appreciated plugin like this become more stable , and than to test it more carefully
#13 Pubblicato: 27/04/2013 02:14:52
kaka
kaka
1 apprezzamenti in 25 post.
Gruppo: User
Thank you again.
Last update: XYPlotRegion_20130427.zip
Sources: https://smath.info/svn/public/plugins/XYPlotRegion/
#14 Pubblicato: 27/04/2013 05:54:43
Gruppo: Moderator
Updated.
5 utenti hanno apprezzato questo post
Radovan Omorjan 27/04/2013 07:07:00, sergio 27/04/2013 09:25:00, Martin Kraska 28/04/2013 03:04:00, Fridel Selitsky 27/04/2013 07:16:00, Davide Carpi 27/04/2013 06:43:00
#15 Pubblicato: 28/04/2013 01:49:03
pol1
pol1
0 apprezzamenti in 4 post.
Gruppo: User
Thanks.
The traces & Number Format function is not working for me (Win 7 64 Bit).
#16 Pubblicato: 28/04/2013 03:01:32
Gruppo: Moderator
Updated.
The last update seems to focus on handling lists of plots. The plugin seems to be under heavy construction.
For plotting functions, the xyplotrregion just evaluates the name, without caring for the argument, therefore plotting pure expressions just as x or x^2 fails.
Also, numbers must be pure numbers, not expressions that can be evaluated to numbers.
I guess that the built-in demo shows sort of development target. It would be interesting to know if expression input for plot items and range limits including unit handling are on the agenda. Anwyway, I am looking forward to the next release.
#17 Pubblicato: 28/04/2013 06:13:01
Gruppo: Moderator
Thanks.
These tabs will be added later. Working on it.
Updated.
Radovan Omorjan 28/04/2013 08:00:00, Davide Carpi 28/04/2013 07:49:00
#18 Pubblicato: 28/04/2013 08:48:50
Gruppo: Moderator
Updated.
Crashing xyplot:
- loading documents created with earlier versions of the plugin
- expressions evaluating to lists but not being lists (e.g. [MATH]±1[/MATH])
Not crashing xyplot:
- using units
empty placeholder produces a line y=x
Is using limit expressions including units (perhaps using placeholders as in old mathcad) on the agenda?
1 utenti hanno apprezzato questo post
#19 Pubblicato: 28/04/2013 10:32:00
Gruppo: Moderator
There is only one placeholder, so I can enter only the expression and nothing more. I don't know whether it is possible to add more placeholders. Limits for the graphs need to be set explicitly (in the formatting dialog).
#20 Pubblicato: 28/04/2013 12:26:50
Gruppo: Moderator
Could global variables be an option?
The user might define or display values of settings like
XYPlot.xmin:0
XYPlot.xmax:3'm -> this would give the independent variable a unit
XYPlot.ymin:0
XYPlot.ymax:"auto" (auto-scaling)
XYPlot.xaxis:"log" or "lin"
XYPlot.title:num2str(n)
XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required.
Settings in the context menu might change or override the variable values or restore them to defaults.
Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
Radovan Omorjan 03/06/2013 07:24:00
  • Nuovi post
  • Nessun nuovo post
