Problem with solver functions
Problem with solver functions - any solver function fails trying to find a zero on a function... - Mensajes
#1 Publicado: 18/9/2023 11:31:30
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
Here is a problem I found trying to solve a simple engineering question.
Please see attached file: Problem with solvers.sm (90 KiB) descargado 1416 vez(es).
#2 Publicado: 18/9/2023 21:17:56
Grupo: Moderator
Sorry I don't have maxima.
Equations are solved with FindRoot().
I also had to make some alterations.
Original y(x) function has unit mismatch.
Solvers don't like direct usage of if() or cases().
You can detect it with Unknowns().
If it doesn't produce a result, there is a problem.
Here is your file solved.
Problem with solvers_solved.sm (95,81 KiB) descargado 1423 vez(es).
A 5 usuarios les gustó este mensaje
Oscar Campo 18/9/2023 21:19:00, churichuro 18/9/2023 22:05:00, NDTM Amarasekera 18/9/2023 23:04:00, ioan92 19/9/2023 5:38:00, Alvaro 19/9/2023 7:28:00
#3 Publicado: 19/9/2023 20:53:43
Grupo: Moderator
I assumed C.1 and C.2 has same units.
Maybe I was wrong at that conclusion.
Worksheet below find a solution between 4-6.
This may be the correct result.
Sorry if I made a huge mistake.
Problem with solvers_revisited.sm (105,7 KiB) descargado 1508 vez(es).
Click to enlarge
Oscar Campo 19/9/2023 21:24:00, Alvaro 20/9/2023 13:14:00
#4 Publicado: 19/9/2023 21:24:06
Oscar Campo
Oscar Campo
Grupo: Moderator
Perfect! Thanks for your cooperation!
