Find rows of matrix
Find rows of matrix - Boolian Test - Mensajes
#1 Publicado: 26/6/2023 14:59:27
RegRetired
RegRetired
8 me gusta en 144 mensajes.
How do I find all rows of a matrix M where column n contains all numbers ≤ x.
I cannot figure out how to use findrows for this. If my text expression is max(M) it works fine, but
the ≤ test does not work for me.
An example would be much appreciated.
Reg CurryLoveland, CO
#2 Publicado: 26/6/2023 15:11:42
RegRetired
RegRetired
Oops, I meant test expression, not text expression.
#3 Publicado: 26/6/2023 17:24:48
Hi. This is an option.
MFind.sm (14,22 KiB) descargado 1534 vez(es).
MFind.pdf (58,83 KiB) descargado 961 vez(es).
NDTM Amarasekera 27/6/2023 7:38:00
#4 Publicado: 26/6/2023 17:56:46
RegRetired
RegRetired
Great! Thanks for all your help.
#5 Publicado: 27/6/2023 12:13:11
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
Another method
Array_Pos.sm (14,76 KiB) descargado 1439 vez(es).
#6 Publicado: 27/6/2023 14:51:06
RegRetired
RegRetired
Ndtma,
Thanks; however, I don’t understand the large numbers in your answer, which are greater than the size of the matrix.
Sorry for my lack of understanding.
#7 Publicado: 27/6/2023 16:48:45
Grupo: Moderator
Ndtma,
It's the item position by linear indexing. Elements can be accessed using a single index, that is the position sorted by rows (base 1). f.e. The 2nd element in the 3rd row is indexed (3-1)*cols(matrix)+2
#8 Publicado: 27/6/2023 17:41:12
RegRetired
RegRetired
Okay, thanks. More complicated than I was looking for. My matrix is 2000x2. But, the responses gave me a clue on how to write my own that is similar to the MATHCAD match function.
Because PTC no longer supports MATHCAD 15 and the future of getting a new license if my computer fails is in question, SMATH is a lifesaver. I am gradually converting my important files to SMATH. SMATH is a real service and excellent option for those in my situation.
I am gradually becoming accustomed to SMATH. I do have one more question on plots. If I click in an XY plot to change some formatting and I accidentally hit my mouse wheel, the plot changes the zoom level. It’s not obvious how to return to the original view. If I close the file and reopen, it is back to normal. At first I thought this was a bug, but searching the forum, I see it is a feature. Is there a simple way to return to the original view when I accidentally move my mouse wheel.
Thanks again.
#9 Publicado: 27/6/2023 18:16:02
I am gradually becoming accustomed to SMATH.I do have one more question on plots.If I click in an XY plot to change some formatting and I accidentally hit my mouse wheel, the plot changes the zoom level.It’s not obvious how to return to the original view.If I close the file and reopen, it is back to normal.At first I thought this was a bug, but searching the forum, I see it is a feature.Is there a simple way to return to the original view when I accidentally move my mouse wheel.
I mentioned that before, about your spoiled X_Y plot
f(x), data ... quick plot is insensitive to command wrt the graph plot.
Differently the X_Y plot will scrap the limits if you slide the graph.
Never put the mouse in the X_Y plot. Resize [X,Y] from the system.
#10 Publicado: 27/6/2023 18:53:46
Grupo: Moderator
Thanks again.
You can try to learn setprop() function for X-Y Plot.
https://en.smath.com/forum/yaf_postst1774_X-Y-Plot-Region.aspx
https://en.smath.com/forum/yaf_postsm59088_X-Y-Plot-Region.aspx#post59088
Here is a simple demonstration I posted before.
DPT_NV plot.sm (20,47 KiB) descargado 1514 vez(es).
#11 Publicado: 27/6/2023 19:42:06
RegRetired
RegRetired
Thanks. Very helpful!
