1 páginas (6 elementos)
Precision on NonLinear Solvers - How enhance precision of solution? - Mensajes
Hi, I want to know what is the method of enhance precision in numerical solution into plugin Nonlinear Solvers.
Precision.sm (12,95 KiB) descargado 1254 vez(es).
WroteI want to know what is the method of enhance precision in numerical solution into plugin Nonlinear Solvers.
There is method unless some reference from source.
Some solvers work more accurately then others.
Generally, they will range from 4 decimals to 15 decimals.
Some functions are so involved in numerical error propagation
that you will have to refine the search range ... Goat radius.
Precision.sm (20,77 KiB) descargado 1273 vez(es).
Yes, using a initial values more accurately I have a better precision. Thanks so much
WroteYes, using a initial values more accurately I have a better precision. Thanks so much
Another example, much different solver.
15 decimals in Engineering works makes no sense
Cheers for your profitable application(s) ... Jean.
Precision Solve.sm (47,69 KiB) descargado 1220 vez(es).
... both high accuracy solvers in same document.
Your stuff collapsed/disabled.
Occasionally, roots(2), roots(3) are profitable.
Precision Solve.sm (68,45 KiB) descargado 1239 vez(es).
sergio 10/10/2021 12:52:00
