Beta: SMath Studio 0.99.6962 (23 January 2019)
Beta: SMath Studio 0.99.6962 (23 January 2019) - Mensajes
#1 Publicado: 22/1/2019 18:39:35
Grupo: Super Administrator
Ofrece numerosas funciones de cálculo y una interfaz de usuario completa, traducida a unos 40 idiomas diferentes. La aplicación también incluye una obra de referencia matemática integrada.
La aplicación puede ampliarse fácilmente según sus necesidades. La herramienta integrada de gestión de extensiones permite acceder a cientos de recursos, tanto oficiales como de terceros, que incluyen: ejemplos de uso, complementos (plug-ins), aplicaciones basadas en SMath Viewer, fragmentos de código, traducciones de la interfaz, libros interactivos, manuales y tutoriales.
Descargar
SMathStudioDesktop.0_99_6962.Mono.tar.gz (1,35 MiB) descargado 2465 vez(es).
SMathStudioDesktop.0_99_6962.Setup.msi (2,23 MiB) descargado 4800 vez(es).
Please note:
  1. There are some known bugs with Worksheet scrolling - will be addressed soon;
  2. There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
    Please use the following to disable high dpi support if required:
To all developers:
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
A 5 usuarios les gustó este mensaje
frapuano 22/1/2019 19:55:00, NDTM Amarasekera 23/1/2019 0:05:00, sergio 23/1/2019 8:48:00, Radovan Omorjan 23/1/2019 15:41:00, Oscar Campo 23/1/2019 17:30:00
#2 Publicado: 24/1/2019 17:35:53
Grupo: Moderator
I have always thought those ones looks weird, especially when they are printed.
- Pi
- Euler's number
- Booelan Equal
- Infinity
It's up to developer to "correct" them anyway. But it is just frustrating to change them in PDF manually )
#3 Publicado: 24/1/2019 19:06:26
- Pi
- Euler's number
- Booelan Equal
- Infinity
Hello.
What you do not like exactly? Font? Style (bold)? Both?
#4 Publicado: 25/1/2019 2:17:30
Grupo: Moderator
for infinity, the size.
for pi/euler/boelan equal, the thickness. they should not to be bold actually.
#5 Publicado: 31/1/2019 3:29:03
Grupo: Moderator
Hello.
By taking into consideration of the silence, should I not wait for change for them?
#6 Publicado: 31/1/2019 4:39:17
Grupo: Moderator
As for pi and e, you can easily get rid of the bold face.
Actually, it would be sufficient to just give pre-defined values an upright face.
In the equations below, the rhs pi and e should be bold, shouldn't they?
I like the idea of the boolean equal being visually different from the evaluation operator
