load a file .sm win10 and linux
load a file .sm win10 and linux - error on linux - Mensajes
#1 Publicado: 26/4/2021 17:22:16
philippe dalet
philippe dalet
18 me gusta en 34 mensajes.
I can load a .sm file on Windows 10 (see joined files), but I have a big problem on linux (Ubuntu 20.04 64 bits - mono 6.12.0.122).
When I have loaded the file .sm, all menus disappears and the sheet displayed becomes bigger .
tested with
smathstudio 0.99 build 7786 and build 7778
Thanks a lot.
Archivo no encontrado.Archivo no encontrado.
Philippe DALET.
#2 Publicado: 26/4/2021 17:58:07
Grupo: Super Administrator
Please could you attach a screenshot from Linux?
#3 Publicado: 26/4/2021 18:59:21
philippe dalet
philippe dalet
philippe
Andrey Ivashov 26/4/2021 19:42:00
#4 Publicado: 26/4/2021 19:15:06
Grupo: Moderator
Nothing is wrong with my setup.
#5 Publicado: 26/4/2021 19:42:52
Thank you. Will check this issue.
#6 Publicado: 27/4/2021 5:20:18
philippe dalet
philippe dalet
Hello Andrey ,
I run smathstudio on a terminal and no error messages are displayed in the terminal.
- [AppDir] PictureRegion 1.10.7786.571 (21 ms.)
- [AppDir] SpecialFunctions 1.12.7786.571 (21 ms.)
- [AppDir] StandardToolboxButtons 1.1.7786.571 (0 ms.)
- [AppDir] TextRegion 1.11.7786.571 (10 ms.)
- [AppDir] PlotRegion 1.11.7786.571 (11 ms.)
- [AppDir] HTMLFileType 1.14.7786.571 (1 ms.)
- [AppDir] XMCDFileType 1.12.7786.571 (3 ms.)
- [AppDir] AreaRegion 1.11.7786.571 (2 ms.)
- [AppDir] SMathFileType 1.11.7786.571 (1 ms.)
- [AppDir] ImageFileType 1.11.7786.571 (1 ms.)
- [AppDir] MathRegion 1.11.7786.571 (2 ms.)
- [AppDir] ViewerFileType 1.1.7786.571 (2 ms.)
I have done the same operation with SMathStudioDesktop.0_99_7691.Mono.
All is OK. No errors.
Ph.D
#7 Publicado: 27/4/2021 14:22:39
philippe dalet
philippe dalet
Philippe,
If you don't mind, attach the *.sm document.
Will add to my Instrumentation Compendium.
I have Pt, T, J advanced thermometers but not alcohol column.
Thanks ... Jean.
Thanks
The file is a correction of a physical problem given to my students.
Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.
#8 Publicado: 9/5/2021 5:36:10
philippe dalet
philippe dalet
Hello Andrey,
I have found the origin of the bug.
In text region (only on linux)
changing
with
eliminates the bug.
no bug on Win10
ph.D
Andrey Ivashov 9/5/2021 7:11:00
#9 Publicado: 9/5/2021 7:44:28
Hello.
changing
with
eliminates the bug.
Please could you try to replace "Arial" with some another Font name installed on your system? Unfortunately I cannot reproduce a bug, but maybe it is because Arial is not available on your system?
If other fonts will work I think I could try to fix this problem.
#10 Publicado: 9/5/2021 19:32:42
philippe dalet
philippe dalet
Hello.
changing
with
eliminates the bug.
I have install Arial fonts on ~/.fonts folder, and the display is correct.
All is OK
Thanks.
philippe
