Problem with integral (again)
Problem with integral (again) - Definite Integral - Mensajes
#1 Publicado: 15/12/2022 12:03:46
Peter Pal Ther
Peter Pal Ther
0 me gusta en 3 mensajes.
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72,86 KiB) descargado 1301 vez(es).
#2 Publicado: 15/12/2022 14:31:15
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
HF.sm (84,02 KiB) descargado 1292 vez(es).
#3 Publicado: 15/12/2022 15:01:55
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73,15 KiB) descargado 1305 vez(es).
#4 Publicado: 16/12/2022 6:41:10
Peter Pal Ther
Peter Pal Ther
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
#5 Publicado: 16/12/2022 6:42:49
Peter Pal Ther
Peter Pal Ther
I do not really understand what you did, but thanks for your help as well.
#6 Publicado: 16/12/2022 9:37:18
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23,97 KiB) descargado 1258 vez(es).
#7 Publicado: 16/12/2022 14:49:11
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 16/12/2022 18:26:00
