Bug in the SMAth by copy & paste of any varuable (CTR+C & CTR+V)
Bug in the SMAth by copy & paste of any varuable (CTR+C & CTR+V) - Mensajes
#1 Publicado: 5/5/2021 7:57:12
Andrey
Andrey
1 me gusta en 44 mensajes.
Dear SSMath Developer,
I think the SSMath version ( "0.99.7792" ) has a bug.
If one couples an object from the math. formula (with help of CTRL+C), then CTRL+V, then appears instead of the variable at the page a graphic
Best regards,
Andrey
#2 Publicado: 5/5/2021 8:48:10
Grupo: Moderator
This is because the plugin implements
public string[] SupportedClipboardFormats => new[] { DataFormats.UnicodeText };
Hence when a plain text is passed the plugin handle the action.
Guess would be needed a "paste as" when multiple plugins are available for such task, with the built-in as default (if any).
Andrey Ivashov 5/5/2021 18:57:00
#3 Publicado: 7/5/2021 9:46:10
Andrey
Andrey
Hello Davide,
thank you for your answer.
Now I have the dilemma, which plugin is responsible for this effect...
I have to turn on and off each plugin step by step to determine it.
Best regards,
Andrey
#4 Publicado: 7/5/2021 13:37:26
Grupo: Moderator
Is the plugin that is shown when you paste the data
So in this case is XYPlotRegion probably
#5 Publicado: 10/5/2021 17:28:30
Grupo: Super Administrator
I've corrected plug-ins to disable handling of text from clipboard by default (as I see it was activated by mistake because of using the same code templates).
So issue is gone. One just need to update installed plug-ins. Note: the latest SMath Studio beta must be used.
#6 Publicado: 11/5/2021 7:52:10
Andrey
Andrey
Hello Andrey and Davide,
thank you for the help and the fixing of this nice tool.
Best regards,
Andrey
