1 páginas (6 elementos)
"Operation cannot be performed with units" for exponential function - Mensajes
I get the "Operation cannot be performed with units" error for a complicated equation involving exponential functions which seem to be the culprit:
Here's the file:
Operation units.sm (17,06 KiB) descargado 1470 vez(es).
Is there a mistake in this equation in SMath ? Here's what it looks like in the original:
Here's the file:
The main error you made is in obtaining the pulsation from the frequency.
Also in the formulation of X5 there were two or three errors of evaluation of the SIN (or cos) of the pulsation multiplied by a time (attention to the use of parenthesis)
Operation_units.sm (17,45 KiB) descargado 1438 vez(es).
Thank you very much. The formula for ω_n from the book did look suspicious to me so I tried removing f_n from it but it didn't help so I thought that the main problem lies somewhere else.
WroteThank you very much. The formula for ω_n from the book did look suspicious to me so I tried removing f_n from it but it didn't help so I thought that the main problem lies somewhere else.
That's a strange hybrid; the equations should be the following:
How can I plot the result as x(t) for t=0 to t=12 s ? From what I remember, plots require x as a variable so I tried with u(x) but I still can't make it work even with all the occurrences of t replaced with x (although I'd rather avoid doing that):
Operation units fixed with plot.sm (16,57 KiB) descargado 1424 vez(es).
![2023-06-26 16_39_37-SMath Solver - [Operation units fixed with plot.sm_].png](/es-ES/files/Download/8Zpvkh/2023-06-26-16_39_37-SMath-Solver---[Operation-units-fixed-with-plot.sm_].png)
