1 páginas (5 elementos)
Least squares method - Least squares method with option to select the power of the polynomial - Mensajes
Another example of curve fitting by the least squares method
with option to select the power of the polynomial, or
select the adjustment of the curve to exponential or potential.
Ajust_by_Last_Square_Selection_Jean.sm (56,61 KiB) descargado 1443 vez(es).
Carlos
Carlos
A 5 usuarios les gustó este mensaje
frapuano 26/4/2019 4:12:00, sergio 26/4/2019 5:33:00, NDTM Amarasekera 26/4/2019 7:20:00, Arie 26/4/2019 9:38:00, Davide Carpi 28/4/2019 5:56:00
WroteAnother example of curve fitting by the least squares method
Hola Carlos !
Couldn't open the attached SS 7030 work sheet.
It happened another time from maybe Alvaro ?
Seemingly caused by 2 of your modules not activated.
My SS 6179 does not closed those two particular modules.
However, I have recognized the flat parabola data set.
I'm sure your proposal will have more applications.
Data sets with flat region best fit by model function,
like this one from al_nleqsolve, always assumed noisy.
Two flat parabolas attached
Thanks... Cheers ... Jean
Genfit [Algo Minimize(Cholesky_3 NonLinear)].sm (37,14 KiB) descargado 1157 vez(es).
Genfit al_ nleqsolve [Edu Model FLAT Parabola].sm (30,24 KiB) descargado 1157 vez(es).
Hola Carlos !
Hola Jean
Here you have a version in 6179 of the work sheet
of the method of adjustment of curves by least squares
Ajust_by_Last_Square_Selection_Jean_V6179.sm (52,77 KiB) descargado 1462 vez(es).
Cheers
Carlos
Hola Carlos.
Thanks for your contribution, most appreciated. More bed time reading.
VISITORS: download all, as they are minimalist Fit Classroom.
One more method is not listed wrt Polynomial fit: the Robert lsq.
Problem is that I can't make it work Mathcad ORIGIN (1)
Next Classroom is large as applied to a large collection of applied projects.
This next Classroom is mostly based on fitting parametric model function(s)
Genfit 0 Ge SubCryogenic.sm (38,93 KiB) descargado 1248 vez(es).
Genfit 00 Carlos-Cholesky.sm (37,2 KiB) descargado 1307 vez(es).
Genfit 0000 Adjust Linear.sm (49,98 KiB) descargado 1332 vez(es).
Genfit 000000 LinfitCheby.sm (77,69 KiB) descargado 1315 vez(es).
Genfit 00000 Linfit Linear.sm (32,52 KiB) descargado 1316 vez(es).
Genfit 000Carlos.sm (45,19 KiB) descargado 1327 vez(es).
Genfit 00000000 PolyOrder.sm (25,86 KiB) descargado 1337 vez(es).
Genfit 000000000 Thiele Corn Thermies.sm (44,32 KiB) descargado 1334 vez(es).
Genfit 0000000 Rational Auto-init ITER.sm (84,24 KiB) descargado 1323 vez(es).
Genfit 0000000000 Rational Num_Denom Order.sm (77,11 KiB) descargado 1347 vez(es).
... a must visit suite.
Three examples most useful for Engineering/Scientific
1. DE sol is intuitive of attempting a fit to your DE
2. Corn Thermies is more local agriculture
3. HadCRUt4 is most advanced Scientific.
So much BS & BK on that blabla parrot
BS & BK => from my old friend Ken [Bull Shit & Book Keeping].
Former Collab Theodore tried all possible orthogonal polynomials,
not to avail vs ChebyShev [I guess Russian does not lie]
Genfit 00000000000 LinfitCheby Order [DE sol].sm (30,19 KiB) descargado 1121 vez(es).
Genfit 00000000000 LinfitCheby Order [Corn Thermies].sm (30,82 KiB) descargado 1147 vez(es).
Genfit 00000000000 LinfitCheby Order [HadCRU].sm (193,77 KiB) descargado 1135 vez(es).
