Solve an equation - How to numerical solve an equation - Mensajes
i have an simple qeustion:
How can i numerical solve an equation with a solver block like in mathcad.
An equation which is transzentent for example
for example:
sin(x) + x = Y --> solve for x
and how can i solve an equation when equation is not transzentent?
like in mathcad with a solver block area....?
thank you br Stefan
Mathcad Block. FindRoot example.sm (4,81 KiB) descargado 1295 vez(es).
where can i find those plugins? I cannot install them directly in the software due to firewall problems thank you!
Wrotehow can i solve an equation when equation is not transzentent?
The attached document is minimalist, but most precious for advanced demand.
root is not documented neither available from f(x) menu
but active from Smath/maple companionship.
Observe how powerful for applied maths.
Solve Maple Companion READ FIRST.sm (58,86 KiB) descargado 1284 vez(es).
Wroteok seems to be that i need some plugins,
https://smath.info/svn/public/
contains the source. Although if you're behind a firewall you might not be able to access this either.
Also, you can create a portable distribution and download/update once you are on another system.
@alyles:
some of the plugins i downloaded but the zip file is empty:
for example: Excel Files Plugin --> downloaded but contains no files (maybe firewall delets the content from it...)
Ill use the solve function
another question:
for example if i have a simple equation:
a+b=c
how can i symbolic solve the equation
so that a=c-b is the result.
If i use solve function all variables need to have a number
I simply want to symbolic solve the equation to a variable without using any numbers asigned to a variable
thank you,
br Stefan
can you provide me with the smath file so that i can look into? Thank you br Stefan
Wrotethank you,
Notice the optimizations are set to symbolic to view results.
You can check and set optimization of individual regions by right click.
symbolic.sm (4,21 KiB) descargado 1287 vez(es).
i downloaded maxima plugin and others but i do get a failure when opening your file see attached picture
There is a file missing:
cmaple.exe / maxima.bat missing
What can i do ?
however smath says maxima plugin is installed:
Thank you br Stefan
WroteThank you but i have a problem i downloaded the latest version
What can i do ?
Thank you br Stefan
It seems your mentioned firewall settings prevented proper installation of Maple plugin.
Usually SMath plugins are saved under this path in Windows 10.
C:\Users\
I can copy my plugins directory on Windows partition and upload it for you to download and copy/overwrite.
But it won't be a convenient way to install plugins. Set an exception to your firewall for SMath downloads.
Maxima is another subject, plugin seems installed but you will need Maxima software to make it work.
Latest version can be downloaded and installed from link below.
https://netix.dl.sourceforge.net/project/maxima/Maxima-Windows/5.46.0-Windows/maxima-5.46.0-win64.exe
You also have to set the path for Maxima.bat under Insert>Maxima control windows>Settings menu.
i need maxima software in order to work properly?
I was thinking the plugin only is enough?
Thank you for the input!
Yes please upload your plugins folder since i cannot download the plugins in the software due to firewall
But what plugin is there required under bin "cmaple.exe"
What he cannot find?
WroteYes please upload your plugins folder since i cannot download the plugins in the software due to firewall
It may have not all plugins, it is just copy of my personal folder.
plugins.zip
what is the name of the maple plugin you mentioned?
I may need maple software in order to work properly i think or?
Thank you br Stefan
Wroteanother question:
Thank you br Stefan
You won't need additional software installation with maple plugin.
I searched maple plugin herer:
https://en.smath.com/list/plugins
but i cannot find the plugin
software needs cmaple.exe in order to work. Where do i find this?
Thank you br Stefan
Wrotebut i cannot find the plugin
https://smath.info:8443/!/#public/view/head/plugins/MapleTools/Resources
It is in cmaple.zip file on this page.
It is in also plugin.zip file I uploaded for you.
