[XlsxImportExport] Exporting Matrix into xlsm File
[XlsxImportExport] Exporting Matrix into xlsm File - Exporting a Matrix and exporting into xlsm file of excel - Mensajes
#1 Publicado: 19/10/2018 16:03:14
Stefan Müller
Stefan Müller
0 me gusta en 45 mensajes.
Hey,
hope the function to export a matrix into an excel with activated makro will work.
Archivo no encontrado.Archivo no encontrado.
It cannot save the file :-(
lg
Stefan
#2 Publicado: 20/10/2018 6:21:29
Grupo: Moderator
Seems a problem of the ClosedXML library when saving in the existing file... I'll check if can be solved in some way...
#3 Publicado: 20/10/2018 7:52:27
Stefan Müller
Stefan Müller
That would be great!!!!!!!!!!!!
Thats at the moment my only problem since i always need a lot of makros in my excel file
Stefan from www.BHDT.at :-)
#4 Publicado: 22/10/2018 8:41:20
Gowand Gravi
Gowand Gravi
0 me gusta en 22 mensajes.
I still don´t get the way how to import xlsx files into SMath files.
It seems, that the xlsx file is found, but there is an error, which sais
my SMath file doesn´t exist.
Would be happy about your help.
Thanks.
G-Tate
#5 Publicado: 22/10/2018 12:31:54
Hi Tate. The word unavaible "Page1" worksheet isn't about a SMath file, it's about a "Page1" worksheet in the "Excel workbook" named "SMath_Test" (without extension), which I guess that don't exist too (because the name of the Excel file requires the extension, not only the name).
You can see examples about how to use the plugin here:
https://en.smath.info/forum/yaf_postst1860_Xlsx-Import-Export-plugin.aspx
or directly here:
https://en.smath.info/forum/resource.ashx?a=1772&b=2
#6 Publicado: 22/10/2018 13:44:28
Stefan Müller
Stefan Müller
Try to add the ending to the filname .xlsx and check if Page1 exists
Seems to be that Page1 is not there in the file
#7 Publicado: 22/10/2018 14:11:27
Grupo: Moderator
If you don't give an extension xlsx is assumed as default; as pointed out by Alvaro and Stefan you have to check if the the worksheet exists in the file
excel workbook = the whole file
excel worksheet = each single tab in the file
#8 Publicado: 24/10/2018 10:26:51
Igor Skarine
Igor Skarine
14 me gusta en 97 mensajes.
Hello Davide,
The plugin doesn't work with the latest Smath beta.
It crashes right away during plugin installation:
I tried it in office on Win10 and at home on Win 7,
all the same. I'm using 32-bit SS on 64-bit Windows.
Davide Carpi 24/10/2018 12:52:00
#9 Publicado: 24/10/2018 12:54:08
Grupo: Moderator
Thank you, confirmed.
Latest release deleted.
#10 Publicado: 25/10/2018 10:17:09
Gowand Gravi
Gowand Gravi
Thank you very much guys!
I didnt get, that the second name needs to be the sheet name from the excel workbook.
I just tried it with the smath file name.
I should´ve think about it, that the import anyway goes to the actual smath file.
:d
G-Tate
#11 Publicado: 25/10/2018 13:22:29
Stefan Müller
Stefan Müller
Could you solve the issue with the import/export of xlsm. Excel Files with Makro?
Best regards,
Stefan
#12 Publicado: 25/10/2018 13:41:10
Grupo: Moderator
Might requires some time. I have to dig the GIT repo for the latest version of CLosedXML that supports .NET 3.5, inspect the code (not mine) and troubleshoot the bug (if possible).
#13 Publicado: 25/10/2018 13:48:46
Stefan Müller
Stefan Müller
A ok i understand. I hope that would be possble in some time.
#14 Publicado: 25/10/2018 13:48:58
Grupo: Moderator
#15 Publicado: 25/10/2018 15:49:05
Grupo: Moderator
After a survey with the debugger, I found that the issue is known without clear solutions.
The error message is:
Exploring the xlsx archive I found a file named "vmlDrawing1" that contains the br tag (a newline tag in html format, should be a self-closing tag to make it compatible with the xml parsers);
That is a button with this text:
Werkstoffdatenbank
öffnen
If you remove the neline character it should save correctly.
#16 Publicado: 25/10/2018 16:05:12
Stefan Müller
Stefan Müller
what you mean with removing the character?
#17 Publicado: 25/10/2018 16:06:38
Grupo: Moderator
Edit the button text, replace newline with a space (go before the first character of the second word, backspace, then space)
#18 Publicado: 26/10/2018 5:18:48
Stefan Müller
Stefan Müller
No working :-(
Now i cant import the loadcases row.
Exporting into xlsm seems not working :-(
lg
Stefan
#19 Publicado: 26/10/2018 9:25:06
Grupo: Moderator
If I use your first SMath Studio worksheet with the latest workbook it seems to work for me.
In your latest worksheet
- first import function name ends with "M" instead of "X" in the subscript that is a function not defined
- in second import the column A of the excel worksheet returns several circular reference exceptions (there aren't stored values even opening it with excel and the plugin isn't able to calculate one... I might return 0 or the cell formula...)
#20 Publicado: 27/10/2018 3:29:22
Stefan Müller
Stefan Müller
dont understand what you mean. I tried but nothing is working :-(
Does the Makro have an influence on the procedure?
