Questions of graph of a function
Questions of graph of a function - Mensajes
#1 Publicado: 31/7/2024 0:55:33
Prmtv
Prmtv
0 me gusta en 49 mensajes.
Hello! Please tell me for 2 questions:
1) How to build a graphs of function if the document has units of measurement? If I do "Ignore inits", then everything works. But I would like to with units of measurements
111.sm (33,1 KiB) descargado 1716 vez(es).
2) Using plugin ComboBox I want to build graphs of 4 functions
Graphs of functions σ.x(x), σ.t(x), Mx(x) are built.
Archivo no encontrado. Archivo no encontrado. Archivo no encontrado.
Graph of functions σ.ekv(x) is not build. Why?
#2 Publicado: 31/7/2024 1:26:33
Grupo: Moderator
Don't "Ignore units", eliminate them.
Easiest way is to divide.
#3 Publicado: 1/8/2024 0:23:24
Prmtv
Prmtv
In my example it doesn't work like that.
#4 Publicado: 1/8/2024 1:37:29
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Очень странное поведение, возьму на заметку. Компоненту не нравится выражение под знаком корня.
#5 Publicado: 1/8/2024 2:55:39
Grupo: Moderator
The success of plotting seems to depend on how the expression is accessed. Possibly it is a Combobox issue.
BTW, in Maxima, the intermediate definition of P is not required. This is a necessary step for X-Y Plot only.
111_Kr.sm (60,2 KiB) descargado 1660 vez(es).
#6 Publicado: 1/8/2024 9:27:50
Prmtv
Prmtv
Если строить график отдельно, то он строится, проблем нет. Именно при Combobox'е не хочет
#7 Publicado: 3/8/2024 1:58:09
Prmtv
Prmtv
Thanks for the answer!
How can I replace it?
on this
#8 Publicado: 3/8/2024 3:49:27
Grupo: Moderator
I only meant to say don't ignore units unless it is utmost necessary.
Here is your file totally working with units and plotted.
111_examination.sm (38,72 KiB) descargado 1733 vez(es).
When I talk about your problem, I guess it is a parse bug of combobox.
Because it can plot normally when function called directly.
And radiobutton and combobox list is not affected if you use like this.
This combobox issue is not limited to XYPlot, 2DPlot is affected too.
When combobox result is directly your symbolic function, it doesn't work.
However, when your function is simplified someway, it can be plotted.
This bug should be examined by author of combobox plugin.
#9 Publicado: 3/8/2024 5:39:17
Grupo: Moderator
on this
I guess you want to set the limits depending on the selected function.
Let the combobox return the index of the selection and then use it to pick the appropriate values from lists.
In Maxima, you also can set the axes labels and the trace legend text using SMath expressions.
#10 Publicado: 3/8/2024 18:45:06
Grupo: Moderator
Most of time, eval() or line() is your friend.
This change made your function available to plot.
#11 Publicado: 4/8/2024 1:21:28
Prmtv
Prmtv
Thanks everyone for your answers!
#12 Publicado: 4/8/2024 1:36:26
Prmtv
Prmtv
on this
Can you tell us more?
If possible with an example.
Yes, I would like to substitute values ​​from the results for set the limits
#13 Publicado: 5/8/2024 3:51:31
Grupo: Moderator
111_Kr2.sm (60,85 KiB) descargado 1691 vez(es).
#14 Publicado: 5/8/2024 4:32:19
Grupo: Moderator
I like the way limits determined by YLimMin, XLimMax, etc.
However, if you rename XYPlot to XYPlots or Plot1 or whatever, this method doesn't work particular plot.
Actually, all XYPlot are affected by XYPlot.option disregarding name of plot.
Is this a bug or a feature?
sergio 5/8/2024 15:36:00
#15 Publicado: 5/8/2024 4:45:30
Grupo: Moderator
As far as I understand, you can control multiple plots individually by providing vector values to the XYPlot-variables. In the settings you select select SourceType->PropertyGrid and provide the index to use for accessing the values.
You find an example in the interactive handbook (Plugins->X-Y Plot Region).
#16 Publicado: 8/8/2024 23:42:02
Prmtv
Prmtv
Thank you very much! That's what I needed.
The only question is: does SMath have auto-scaling of axes as it was in Mathcad? this would greatly simplify the process)
#17 Publicado: 9/8/2024 1:43:28
Grupo: Moderator
Использование Properties source - это исторически первый способ управления компонентом из документа, он был оставлен для совместимости со старыми документами.
Автомасштабирование в компоненте XY Plot не реализовано из-за того, что я не нашел удобного алгоритма поведения для комбинации явных и неявных графиков. Для отображения неявного графика область должна быть задана конкретно, а для автомасштабирования наоборот не задана.
#18 Publicado: 9/8/2024 15:04:34
Grupo: Moderator
I can add this option to customize the properties
#19 Publicado: 12/11/2024 7:02:29
Mo
Mo
0 me gusta en 34 mensajes.
hi, For some reason the "Property source" is not shown now. I am using version 1.2 build 9018 dated 09-sep-2024.
how to assign/control plot properties now?
#20 Publicado: 12/11/2024 8:08:01
Grupo: Moderator
The answer can be found here.
