Slope Stability Analysis
Slope Stability Analysis - A basic approach to find cutting points of strips with profile and slip circle - Mensajes
#1 Publicado: 16/9/2023 5:01:44
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
Ref: Example 12.2 (Page 296) - Soil Mechanics : Principles and Practice by G.E. Barnes.
The attached SM file demonstrates how to find cutting points of strips with the slope profile and slip circle.
(for an assumed strip width of 1m. which can be changed if necessary).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.pdf (238,31 KiB) descargado 1105 vez(es).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.sm (320,99 KiB) descargado 1817 vez(es).
sergio 16/9/2023 6:05:00, dio pants 31/10/2023 2:31:00
#2 Publicado: 16/9/2023 7:51:13
NDTM Amarasekera
NDTM Amarasekera
A small text correction to my post #1.
Sorry for inconvenience please.
Point A and Toe are also same.
Alvaro 17/9/2023 17:18:00, Oscar Campo 16/9/2023 10:55:00
#3 Publicado: 16/9/2023 13:06:16
NDTM Amarasekera
NDTM Amarasekera
Second correction, as the variable Hvc is no longer used in the entire program. Please delete the entire line as indicated.
Extremely sorry.
#4 Publicado: 20/9/2023 1:55:02
NDTM Amarasekera
NDTM Amarasekera
The complete solution to Slope Stability Analysis of above example.
Analysis is carried out in 2 parts.
1. With one assumed Center of a slip circle to explain steps involved and resulting cordinates of strips etc., and checked with ACAD drawing.
2. Program to find the minimum factor of safety using multiple arrays of centers.
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.pdf (334,22 KiB) descargado 1092 vez(es).
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.sm (522,82 KiB) descargado 1743 vez(es).
Alvaro 20/9/2023 13:14:00, Oscar Campo 20/9/2023 6:39:00, ioan92 20/9/2023 8:01:00
#5 Publicado: 21/9/2023 7:45:50
NDTM Amarasekera
NDTM Amarasekera
Please make the correction as shown ( replace A with -A in page 3).
Even without this correction, the program will run in most cases, but will give
wrong values for AA for some center cordinates.
This correction is an improvement.
Sorry for the inconvenience.
Oscar Campo 21/9/2023 13:47:00
#6 Publicado: 28/10/2023 21:32:18
NDTM Amarasekera
NDTM Amarasekera
An improved method to my post #5.
I get Wrong Values OR Errors when using the "Findroot()" function for some center cordinates.
This new method mainly uses "root()" function, with few supporting programs.
Slip Circle Intersection Points - TO FORUM.pdf (392,59 KiB) descargado 1046 vez(es).
Slip Circle Intersection Points - TO FORUM.sm (247,73 KiB) descargado 1744 vez(es).
Oscar Campo 28/10/2023 22:03:00, Alvaro 29/10/2023 3:11:00, sergio 30/10/2023 15:59:00
