1 páginas (7 elementos)
sin1309X=1140X, Can it be solved? - Mensajes
subjected Equation is detailed as under:
In a Circle if S is arc length, L is chord length and R is Radius and 'Theta' is angle of arc subtented at centre of circle in radians.
then by geometry S = 'R'.'Theta', where Theta in radians and R is Radius.
or Theta/2 = S/2R -----Eq 1
and also in triangle made by R , L/2 and base from centre to one end of L/2
Sin (Theta/2) = L/2R ----Eq 2
thus from Eq 1 and 2
Sin (S/2R) = L/2R
if an Arc length 'S' is given = 2618.
its chord length 'L' is also given = 2280.
then equation will be Sin (1309X) = 1140X, Where X =1/R
Sin (S/2R) = L/2R
The result iz zero (see the example of finding roots).
Try, for instance, function solve and solve the equation sin(1.309*x)-1.140*x (there should be three values)
By the way, if we try to plot the function sin(1309*x)-1140*x and zoom in, we are going to see very small numbers with the 15 significant digits on the axis ticks, say x.xxxxxxxxxxxxxxE-xx. This is rather hard to read especially on the x axis. I suppose that there should be used the same number of decimal places as defined under Tools=>Options=>Decimal places, or something else?
WroteThe result iz zero (see the example of finding roots).
Dear Frnds
Actually in excel, values can easily be brought out by using Goal seek option. I am pasting here the same:
Radius Excel Formula and value
C9 - value = cos(1309/C9)-((C9-525)/C9)
1534.578119 -0.000162479
Here I put a additional formula:
sin(1309/R) - L/2R =0.
Radius C7 value Excel Formulae and value
=SIN(1309/C7)-(1140/C7)
1455.558167 -0.000306041
Next: Solution of sin(X ) or cos(X ) or other trigonometric functions could only be solved in form of expansion of series. So in place of sinaX or cosaX , that series can be replaced up to the required terms wrt the required decimal. But again it is a tedious due to multi power series
Sin(X) = X – (X^3)/3! + (X^5)/5! – (X^7)/7! + ---- -------- -------
Cos (X) = 1 – (X^2)/2! + (X^4)/4! – (X^6)/6! + ----- ----- ----
My TI 89 Titanium says 0 :P
If anyone cares...
If anyone cares...
We have a maths problem, not an Smath problem. 0 is a correct answer. AFAIK there is no other.
I solve using OpenOffice Spreadsheet (Goal Seek)and I get R = 1457.555. Zero is not the only answer, I believe.
Here it is, again
