Incorrect Unit calculation
Incorrect Unit calculation - Incorrect Unit calculation - Mensajes
#1 Publicado: 31/1/2015 23:11:42
nik
nik
0 me gusta en 8 mensajes.
Hi all,
some problem which unit calculation
K:8.87
α:1
β:0.43
γ:0
b:200*'мм
Kα:K*(α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4}))^0.5=#
result: Unit does not match((((
#2 Publicado: 1/2/2015 9:39:04
Grupo: Moderator
The error seems correct. Just make a dimensional analysis on α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4})
You sum something dimensionless with 1/мм^2 and 1/мм^4
#3 Publicado: 2/2/2015 19:45:39
nik
nik
I`m not convert unit of measure, math operation only value. mm^4 you real?? what a dimension, square? cube or astral?
#4 Publicado: 2/2/2015 20:11:26
Grupo: Moderator
Maybe the attached picture helps a little bit more to understand the issue...
As stated previously, you can't sum apples and oranges; therefore the error message seems consistent...
#5 Publicado: 3/2/2015 18:46:44
nik
nik
ок,
formula
#6 Publicado: 3/2/2015 19:20:22
Grupo: Moderator
Thanks for sharing the original formula, this makes more sense; seems you have missed or merged a parameter (alpha) with a variable (a)
Best regards,
Davide
nik.sm (17,74 KiB) descargado 1394 vez(es).
#7 Publicado: 4/2/2015 18:04:59
nik
nik
this is font trouble, real value "a"
#8 Publicado: 4/2/2015 19:20:46
Grupo: Moderator
Seems strange, because in this way the formula has both mathematical sense (alpha*x^0+beta*x^2+gamma*x^4) and physical sense (homogenous units involved in the calculation)... there is some literature about this formula? (where it is used? has an author?)
