Analog Clock
Analog Clock - A simple animation - Mensajes
#1 Publicado: 9/7/2013 10:24:35
Grupo: Moderator
A simple animation
Best Regards,
Davide
AnalogClock_viewer.7z (355,86 KiB) descargado 832 vez(es).
A 4 usuarios les gustó este mensaje
ioan92 9/7/2013 11:21:00, Вячеслав Мезенцев 11/7/2013 13:12:00, Andrey Ivashov 10/7/2013 8:27:00, Fridel Selitsky 9/7/2013 14:27:00
#2 Publicado: 9/7/2013 16:51:49
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22,29 KiB) descargado 1425 vez(es).
Davide Carpi 9/7/2013 17:15:00, Andrey Ivashov 10/7/2013 8:27:00
#3 Publicado: 9/7/2013 17:20:04
Grupo: Moderator
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
#4 Publicado: 11/7/2013 5:37:01
Fridel Selitsky
Fridel Selitsky
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21,44 KiB) descargado 1490 vez(es).
Вячеслав Мезенцев 11/7/2013 13:12:00, Davide Carpi 11/7/2013 8:45:00
#5 Publicado: 11/7/2013 8:49:18
Grupo: Moderator
I see, wonderful
#6 Publicado: 16/7/2019 0:08:53
Best Regards,Ber7.
Glorious old vintage, before I joined Smath.
More elegant needles in there ... needs be animated
attach]31143[/attach]
#7 Publicado: 18/7/2019 14:24:18
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38,86 KiB) descargado 1377 vez(es).
click_low.wav (171,1 KiB) descargado 365 vez(es).
alarm.wav (891,03 KiB) descargado 374 vez(es).
frapuano 18/7/2019 14:53:00, Alvaro 19/7/2019 2:04:00
#8 Publicado: 19/7/2019 2:25:06
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
frapuano 19/7/2019 5:23:00, Oscar Campo 19/7/2019 17:39:00
#9 Publicado: 19/7/2019 18:15:08
Oscar Campo
Oscar Campo
Grupo: Moderator
Thanks for your suggestions Also I considering the seconds in the movement of the minutes hand for a more realistic appearance.
I've updated the file and I uploaded the new one, you can check it here.
