Roots - intersection points
Roots - intersection points - Trouble with finding intersection points of a line and a parabola using "roots" command. - Mensajes
#1 Publicado: 14/4/2023 16:43:40
SERGIO MARQUES DE SOUZA
0 me gusta en 5 mensajes.
Good afternoon everyone.
I'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
Roots.sm (8,44 KiB) descargado 1364 vez(es).
Click to enlarge
#2 Publicado: 14/4/2023 17:35:21
As doctored ... Jean
Roots Doctored.sm (9,38 KiB) descargado 1384 vez(es).
#3 Publicado: 14/4/2023 18:41:21
Hi Sergio. There are a 3 argument version of roots, where the third is a guess value for the root.
Roots.sm (9,84 KiB) descargado 1406 vez(es).
#4 Publicado: 15/4/2023 8:54:21
'roots' is essentially based on differentiable function.
Often, in Engineering works you don't have differentiable functions,
Gamma(x), spline fit ... etc.
In those cases, use the X(Φ,a,b,ε) utility.
roots Gamma(x).sm (18,54 KiB) descargado 1366 vez(es).
#5 Publicado: 15/4/2023 19:31:34
Grupo: Moderator
Here your solution solved with maple plugin.
No need to enter guess points for this.
Maxima can solve it too, similarly.
PS: MapleCorrect() function can be found here.
Assign() function can be used instead of str2num() + num2str() + strrep().
#6 Publicado: 15/4/2023 20:44:04
Grupo: Moderator
My personal favourite way to handle solver results is Davide's at() substitution function.
#7 Publicado: 16/4/2023 2:49:20
Hi. This is another way.
Roots.sm (16,66 KiB) descargado 1361 vez(es).
#8 Publicado: 16/4/2023 9:11:08
Many Smath built-in functions are not differentiable.
diff(▄ ▄) not defined ... Airy example attached.
roots Airy.sm (11,05 KiB) descargado 1341 vez(es).
#9 Publicado: 16/4/2023 11:22:35
Grupo: Moderator
What the heck? Can we use maple keywords if they are written as `function`?
This is so mind-blowing, thanks Razonar.
Alvaro 17/4/2023 17:27:00
#10 Publicado: 16/4/2023 18:34:02
#11 Publicado: 17/4/2023 1:44:30
Grupo: Moderator
I found a Windows laptop.
And tried Maxima plugin Solve().
It can solve easily.
