Custom Functions plugin
Custom Functions plugin - functions: extended Max and Min, Unit of Measurement, Order of Magnitude - Mensajes
#41 Publicado: 19/8/2014 5:26:39
Jure
Jure
0 me gusta en 5 mensajes.
In the last version of Smath, the plugin is not working any more
#42 Publicado: 19/8/2014 6:25:12
Grupo: Moderator
Hello jurep, what kind of problem did you notice? Your Operating System?
#43 Publicado: 20/8/2014 4:43:37
Jure
Jure
Hi!
I get this message
test
my system is win7
#44 Publicado: 20/8/2014 5:14:54
Grupo: Moderator
Seems that the file was saved using an old version of the plugin; meanwhile standards for plugins design was well defined, so a unique identifier (guid) was introduced for each plugin. It is easy to fix and you can do it by yourself.
Please open your worksheet with a text editor (Windows' Notepad, Notepad++, etc...)
Look at the headers of the XML code; you should see a block of code like this
<dependences>
      <assembly name="SMath Studio Desktop" version="..." guid="a37cba83-b69c-4c71-9992-55ff666763bd" />
      <assembly name="..." ... />
    </dependences>
Also, you should see that the plugin has saved a null Guid
<assembly name="Custom Functions" version="..." guid="00000000-0000-0000-0000-000000000000" />
To solve the issue, replace the null guid of Custom Functions with the official guid
18dadffd-79a3-4cf9-aee1-d66deb0ea720
Let me know if this solve your issues
Best regards,
Davide
#45 Publicado: 20/8/2014 5:35:50
Jure
Jure
Thanks for super fast replay! It works now! thanks again!
#46 Publicado: 20/8/2014 5:46:28
Grupo: Moderator
You're welcome
#47 Publicado: 3/9/2014 17:34:45
Grupo: Moderator
Has sys2mat.1() been withdrawn or is this a bug?
#48 Publicado: 4/9/2014 8:25:42
Grupo: Moderator
ops...
I've lost the sources of that update, not uploaded in the SVN, so I've rebuilt the missing functions but seems that I've forget the function. I'll restore it on the next update. :d
#49 Publicado: 2/12/2014 7:23:03
Grupo: Moderator
PLUGIN UPDATED
- restored sys2mat.1
- Max()/Min() now returns itself when a variable is not defined (SS-114)
- Diag() accept systems as input (SS-1248)
sergio 2/12/2014 7:57:00
#50 Publicado: 16/12/2014 8:02:40
csb531
csb531
0 me gusta en 24 mensajes.
I found this extra functions today... great, I will especially use the Max and Min functions.
Thank you very much Davide
#51 Publicado: 22/9/2015 4:02:09
Grupo: Moderator
sys2mat.1() again seems to be missing...
sys2mat.1.sm (4,89 KiB) descargado 1637 vez(es).
#52 Publicado: 22/9/2015 5:11:36
Grupo: Moderator
works for me... what version of the plugin do you have?
#53 Publicado: 22/9/2015 5:51:39
Grupo: Moderator
seems to be up to date.
EDIT: The function is avaiable, but obviously there have been changes in handling text indices. I choose sys2mat.1() from the dynamic assistant but the .1 won't display as text index. Once I delete the dot and type it in again, then the text index appears and the function becomes undefined.
Here is the system information:
Mostrar spoiler
Radovan Omorjan 22/9/2015 7:15:00, Davide Carpi 22/9/2015 6:12:00
#54 Publicado: 22/9/2015 6:08:52
Grupo: Moderator
Found the bug, I'll update the plugin ASAP
#55 Publicado: 22/9/2015 6:40:10
Grupo: Moderator
PLUGIN UPDATED
- fixed localization issues in sys2mat.1() (thanks to Martin Kraska)
#56 Publicado: 16/1/2016 12:40:38
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346 and later and SMath Studio 0.97.5737
  • added Abs(1) (extends built-in abs(1) to matrices);
  • added Conjugate(1);
  • improved description of InterpBilinear(5);
  • refactoring;
2016-01-16 16_42_21-SMath Studio Desktop - [CustomFunctions_examples.sm].png
ioan92 16/1/2016 12:49:00, sergio 16/1/2016 14:24:00
#57 Publicado: 19/1/2016 12:51:21
Grupo: Moderator
Thank you Ioan, bug confirmed. I'll fix it ASAP.
ioan92 19/1/2016 14:42:00
#58 Publicado: 19/1/2016 17:24:51
Alternately if your stuff is in appropriate vector(s)
make it "Smath style"
Utilities Conjugate_Absolute.sm (11,18 KiB) descargado 1727 vez(es).
#59 Publicado: 3/3/2016 15:25:21
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5737 and later
- Added var2str(1) and var2str(2) [customized versions of num2str for numerical display in 2D plots];
- Added functions from (ex) Functions' Extension: at, ternary booleans, cases, Kronecker, perc, permil;
- Added clone of Ceil() & Floor() from Statistical Tools;
- Added clone of Unknowns() from NonlinearSolvers;
- Added glyph for Conjugate();
- Fixed issues of stack/augment in placeholders for Max() & Min();
- refactoring;
Вячеслав Мезенцев 3/3/2016 15:57:00, Radovan Omorjan 3/3/2016 15:27:00, ioan92 3/3/2016 16:51:00
#60 Publicado: 7/3/2016 9:09:06
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346 and SMath Studio 0.97.5737 and later
- Max and Min reworked to use numerical engine (to fix this bug);
