Custom Functions plugin
Custom Functions plugin - functions: extended Max and Min, Unit of Measurement, Order of Magnitude - Mensajes
#121 Publicado: 24/5/2021 16:18:17
Grupo: Moderator
Fixed, plugin updated.
Andrey Ivashov 24/5/2021 16:58:00, sergio 25/5/2021 4:06:00
#122 Publicado: 31/5/2021 4:17:38
Martin_B
Martin_B
22 me gusta en 84 mensajes.
The function mat2sys.1 affects also the inner matrix, if evaluated numerically AND if this inner matrix contains only element.
Is that really the intended behaviour?
I wanted to build my own mat2sys.1 using num2str, ... replace mat with sys... str2num
Looks like str2num is the "culprit", at least in my own function (only while evaluating numerically).
Maybe the better question is: Is this behaviour of str2num intended?
#123 Publicado: 31/5/2021 11:02:37
There are miscellaneous applications, mostly Fourier stuff.
Fourier Geometric Coplanar COMPLEX.sm (17,78 KiB) descargado 1788 vez(es).
#124 Publicado: 31/5/2021 11:20:27
... I don't understand the remaining of the demand.
#125 Publicado: 31/5/2021 11:24:14
#126 Publicado: 31/5/2021 12:13:07
Grupo: Moderator
The behaviour is driven by the evaluation of the outer sys(); on numerical evaluation, the "first level" of 1x1 matrices is suppressed.
I'm not sure if it is really intended, but it might be part of the special behaviours of sys() (have to check the code/ask Andrey).
NDTM Amarasekera 31/5/2021 12:29:00, Martin_B 31/5/2021 12:37:00
#127 Publicado: 31/5/2021 13:02:53
Martin_B
Martin_B
By now I think it's the general behaviour (intended or not), that 1×1 matrices are evaluated to its element (numeric).
That's why I use Gettype() to check if an element was found.
#128 Publicado: 9/6/2021 9:49:05
Martin_B
Martin_B
Found a bug in cases in combination with for loops and continue:
Two identical loops.
If if(,,) is used, continue causes the rest to be skipped (as expected).
If cases(,,) is used, continue has no effect
appVersion(4)="0.99.7822.147"
#129 Publicado: 15/6/2021 2:40:15
Martin_B
Martin_B
Sorry for pulling this to the surface.
I am wondering if I am the only one, who's using continue/break in a similar way.
At the moment I replace every cases with if(s), when used in combination with for loops and continue/break.
#130 Publicado: 15/6/2021 3:19:03
Grupo: Moderator
Confirmed, with a strange behavior.
Reversing the cases makes it correct.
#131 Publicado: 15/6/2021 3:46:04
Grupo: Moderator
At first glance I'm not sure about the cause, I'll check it.
However looking at the screenshot I have to point out once again that in general you shouldn't put definitions inside cases().
Unlike if(), when a condition or a case fails instead of throwing an error the whole function is returned like if doesn't exists. The consequence is that every argument is exposed and preprocessed, with potential unwanted behaviors respect to the expected logic. This is on the edge of SMath possibilities, but is what makes possible to use cases() whereas if() usually fails.
#132 Publicado: 15/6/2021 3:55:31
Grupo: Moderator
Nothing to be afraid, is in the best interests of anyone having things to work flawlessly
Interesting, nice catch .
#133 Publicado: 15/6/2021 7:56:43
#134 Publicado: 19/6/2021 8:12:37
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7822 and later
  • image2rgb/image2rgba: implemented different algorithm for linux users;
  • image2rgb/image2rgba fixed exception on failed disposal of temporary files;
#135 Publicado: 19/7/2021 15:38:47
Grupo: Moderator
cases() refuse to be vectorized if it is a function.
#136 Publicado: 19/7/2021 16:13:54
Martin_B
Martin_B
Sometimes a line at the right place helps a lot.
And hovering the mouse over an expression helps finding the glitch.
Oscar Campo 29/8/2025 10:03:24
#137 Publicado: 19/7/2021 18:02:45
Grupo: Moderator
Hah, I get it. Mysterious (but necessary according to this) line again.
Even though I use smath several years, I still forgot some of its tricks.
No need to hover the mouse, lasterror() has the same behavior.
#138 Publicado: 29/8/2025 9:50:08
Grupo: Moderator
ClearAll() affects the built-in variable lasterror, depending on the argument provided. Yet, the description doesn't mention any significance of the argument and also promises not to touch pre-defined objects.
Oscar Campo 29/8/2025 10:03:44
#139 Publicado: 29/8/2025 12:38:36
Grupo: Moderator
Seems lastError is stored in the context, unlike other predefined variables. I'll add an exception.
edit: plugin updated
Editado 29/8/2025 13:56:40
Martin Kraska 29/8/2025 21:36:21, Oscar Campo 29/8/2025 22:06:18
#140 Publicado: 11/9/2025 9:51:54
Grupo: Moderator
I think that we would need more brackets here in order to make the scope of the at() or the corresponding operator function visible.
Editado 11/9/2025 9:55:05
