1 páginas (4 elementos)
problem with stack and reverse - Mensajes
This is a piece of a script to draw a IPE/HE beam cross section; the idea is to draw the section using the double symmetry of the profile, rather than do it point by point, but I've found some problems/incongruences... I think can be bugs, but I'm not sure...
stack reverse problems.zip
regards, w3b5urf3r
bugs%2fstack%20reverse%2001.pngregards, w3b5urf3r
Hello w3b5urf3r,
I mentioned that in some other post reverse-and-interpolation
The problem could be resolved if you use Numerical optimization for the variables defined with reverse(). Just use it for your Q and S variables and everything will be fine.
Davide Carpi 20/5/2012 7:00:00
WroteHello w3b5urf3r,
done, thank you!
P.S. this problem can't be resolved inside functions (see the end of updated stack reverse problems.zip)
Radovan Omorjan 20/5/2012 8:21:00
WroteWroteHello w3b5urf3r,
done, thank you!
Actually, it can. Inside your function use eval(reverse(...)) instead reverse(...).
