Frame and Beam analysis with Moment distribution method
Frame and Beam analysis with Moment distribution method - Problem with Array - Mensajes
#1 Publicado: 22/2/2023 9:03:54
yoswos
yoswos
0 me gusta en 6 mensajes.
I have been trying to convert this Smath Studio file to Mathcad
and I have gone this far but found an error that said
"This Array index is invalid for this array."
Please comment on it.
Thanks.Archivo no encontrado.Archivo no encontrado.
#2 Publicado: 22/2/2023 10:36:44
Mathcad index starts 0 ... Smath 1
Your Smath document turns red Syntax is incorrect.
To be doctored ... so immense !
#3 Publicado: 22/2/2023 15:49:29
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
The SMath program you are referring was posted sometime back to the FORUM by me.
It was based on the moment distribution method, and use of it is limited only to
cases of 2 span substitute frames.
Recently, I posted a couple of examples based on the stiffness method. which can
be used for any practical number of spans.
See the following link.
https://en.smath.com/forum/yaf_postsm80558_RC-Subframe-Analysis-by-Stiffness-Method.aspx#post80558
I have redone your example using this stiffness method, attaching it with a definition file.
These two files must be in the same folder please.
Unfortunately these two sm files are lengthy, and I sincerely welcome forum members
to propose any improvements.
I am extremely sorry that I am unable to check your example Mathcad file.
Cheers,
Include_Programs-R10.sm (118,66 KiB) descargado 1324 vez(es).
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method.sm (387,81 KiB) descargado 1450 vez(es).
Davide Carpi 23/2/2023 10:06:00
#4 Publicado: 23/2/2023 0:40:11
NDTM Amarasekera
NDTM Amarasekera
Above example simplified to show only the Support and Column Moments.
Definition file not required.
Cheers
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.sm (232,84 KiB) descargado 1490 vez(es).
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.pdf (333,69 KiB) descargado 895 vez(es).
#5 Publicado: 23/2/2023 9:49:58
yoswos
yoswos
Thank you.
#6 Publicado: 23/2/2023 11:29:51
NDTM Amarasekera
NDTM Amarasekera
Davide Carpi 23/2/2023 15:14:00
