Run - Extends SMath Studio with the ability to run other worksheets in background - Mensajes
#1 Publicado: 12/4/2016 14:46:51
Grupo: Moderator
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
  • installation: SMath Studio: Tools > Plugins... > Online Gallery (be sure to have the "Exclude beta-versions" unchecked);
  • documentation: (beta) Run Example.7z (4,48 KiB) descargado 1057 vez(es)..
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
A 5 usuarios les gustó este mensaje
sergio 12/4/2016 15:41:00, ElSid 12/4/2016 16:35:00, frapuano 12/4/2016 16:49:00, Вячеслав Мезенцев 13/4/2016 1:14:00, Kemili 13/4/2016 13:38:00
#2 Publicado: 12/4/2016 16:09:25
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
Will this allow us to transfer data? SWEET!
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile,
wfile, importData, exportData, ...).
#3 Publicado: 13/4/2016 14:21:48
Grupo: Moderator
Is more targeted to process data "remotely"; data transfer is driven by existing functions (also include());
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile, wfile, importData, exportData, ...).
I think the only other way, in the scenario drawn in the example of the first post, would be to transfer data via functions, that is not a feasible way as for now.
Also, I have to improve the log system to better recognize if there are errors in the target worksheets.
#4 Publicado: 15/4/2016 17:12:30
Ruben Sidranski
Ruben Sidranski
How is this different than "Include" plug in by Uni?
#5 Publicado: 16/4/2016 12:39:42
Grupo: Moderator
Mainly:
include() loads the SMath variables/functions from the target worksheet into the one in use, while in Run() each worksheet is indipendent;
include() can't run non-math regions (ComboBoxList, etc...) while Run() execute everything;
#6 Publicado: 27/8/2016 2:28:06
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
  • requirements: SMath Studio 0.98.5935 or later;
  • Problem in 98.6081?
    #7 Publicado: 27/8/2016 8:48:06
    Hello collab ndtma,
    Don't take my comment bad. Your snippets are always blurry [not comfortable].
    You can "PrintScreen" paste in Paint to select the portion. That results in
    huge BMP... then reduce to 256 via IrfanView: superfreeware of multiuse ...
    mostly: sharpen image, superbe Lanczos zoon [square/rectangular] gray/color
    images ++++ .
    I use this technique as well as capture a selected region from WinGrab
    [freeware]. Wingrag has more options to reduce 256 colors, in many difficult
    cases of better quality than IrfanView, though is does not apply to Smath snippets.
    Cheers, Jean
    #8 Publicado: 27/8/2016 10:10:59
    NDTM Amarasekera
    NDTM Amarasekera
    Hello Jean,
    Thanks for your valuable suggestions.
    #9 Publicado: 27/8/2016 10:29:53
    Grupo: Moderator
    Problem in 98.6081?
    Hello ndtma,
    yes, seems there are isSies with the process handle. I'm looking to find the cause and if I can solve it
    #10 Publicado: 29/8/2016 13:05:21
    Grupo: Moderator
    Issue found.
    edit: fixed in SS 0.98.6179
    #11 Publicado: 1/11/2018 15:30:04
    Kyle Sullivan
    Kyle Sullivan
    2 me gusta en 9 mensajes.
    Hi Davide, I created my own example with a 3x3 excel table and it takes about 6 seconds for the "Run" function to execute each row of test data during the for loop. The smath sheet it's running contains 2 variables multiplied together and output as a variable 'd'. Your entire example runs in 22 seconds, with definitely a bit more complexity, but not much. Any ideas here? I'd like to run 400 rows of data (load cases for different members) through a calc sheet and collect the results, just like you've done (except only one calc sheet, not 3 like you've done).
    thx!
    #12 Publicado: 2/11/2018 7:24:46
    Grupo: Moderator
    Currently each Run function triggers a new instance of SMath Studio; this means that all the initialization process must be done every time, rising the execution time. What you can try is to change the logic to start a single run with multiple worksheets, and init/finalize each loop step in a dedicated file.
    new loopSheet.sm
    initCalc.sm
    handleCalcResults.sm
    Kyle Sullivan 2/11/2018 13:55:00
    #13 Publicado: 2/11/2018 14:32:57
    Kyle Sullivan
    Kyle Sullivan
    Thanks for the response Davide.
    So I went ahead and tried out your idea, it does solve the only 'running' once issue and finishes the script in 6 seconds no matter what.
    But now I have the issue where the Run(exec) command does not seem to be running all the scripts in the exec matrix, or somehow it's only saving the first 'calcResults' in 'allResults'. That said, I was successful in manually looping the 3 sheets, so I thin something is going on incorrectly in the run(exec) line.
    You can see what I did in the gifs below if you open them full size in a new tab..
    Thoughts?
    Calc completed successfully by manually looping the 3 sheets:
    Manual loop method works
    Calc running with loop sheet, only records first row result:
    #14 Publicado: 2/11/2018 15:52:52
    so I think something is going on incorrectly in the run(exec) line.
    That I don't understand the idea/purpose of run does not indicate it is useless.
    Do you mean run would calculate in a cash of some sort a selection of work sheets
    and then would show all calculated by clicking "Open file" ?
    #15 Publicado: 2/11/2018 18:21:03
    Thoughts?
    Hi K. Gif shows that you modify iniCalc.sm (disabling some calcs) but don't save it, so others SMath files read the original iniCalc.sm, not the modified. Is this the issue or I'm are not understanding something else?
    #16 Publicado: 3/11/2018 0:05:52
    Kyle Sullivan
    Kyle Sullivan
    I reran it after saving everything and the same thing happened..here's a non-gif image and the files. I guess Davide's example ran fine so I should be able to figure this out haha. I'm currently troubleshooting so stay posted
    testCalc.sm (3,48 KiB) descargado 1693 vez(es).
    handleCalcResults.sm (5,08 KiB) descargado 1701 vez(es).
    initCalc.sm (9,58 KiB) descargado 1642 vez(es).
    input.xlsx (8,07 KiB) descargado 1129 vez(es).
    loopSheet.sm (10,61 KiB) descargado 1642 vez(es).
    This gave me what I want..
    Run(exec)
    Run(exec)
    Run(exec)
    I quit, there's something with run() only running files if they have a different name, or the Run(exec) is called again (like above). I created a new, simpler example.. Below shows that if exec is defined with 3 separate but identical calc.sm files (calc1.sm, calc2.sm, etc) then run(exec) will run all 3 files and the allResults var is fully populated. If I define exec as a vector with all the same calc.sm files then it won't work and allResults will just end up with the first result.
    calcSheet.sm (5,68 KiB) descargado 1661 vez(es).
    loopSheet.sm (5,49 KiB) descargado 1664 vez(es).
    #17 Publicado: 3/11/2018 15:46:07
    Grupo: Moderator
    You are right, I have to investigate it.
    #18 Publicado: 3/11/2018 20:54:20
    Document calcSheet calculates nothing [no maths/formula(s)/result(s)]
    Certainly no gadget will retrieve something from nothing, is it ?
    If calcSheet calculates something, save to file and retrieve from
    any other Smath work sheet. On the other hand, you may save formula(s)
    in calcsheet and retrieve from any other Smath work sheet then modify
    the formula(s) in the working document ... per say change parameters.
    You say nothing about what you have in mind.
    #19 Publicado: 3/11/2018 22:54:49
    Kyle Sullivan
    Kyle Sullivan
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data my previous example actually took one of the values in the 'current row' and multiplied it by 3. I just wanted to make the example here as simple as possible so we could hone in on the problem.
    #20 Publicado: 4/11/2018 12:38:23
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data my previous example actually took one of the values in the 'current row' and multiplied it by 3.I just wanted to make the example here as simple as possible so we could hone in on the problem.
    Simply attach the basic project and describe the next part of the project.
    As you explain, it looks weird from maybe baby simple.
