Editable Image Region - Plugin Update
Editable Image Region - Plugin Update - Mensajes
#61 Publicado: 20/4/2016 18:49:37
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
Plugin updated with [[R] [G] [B] [A]] functionality. Use SMath 0.98 +.
Given the thematic of the example, Happy Birthday!!! (to whoever this would apply).
Test and report!
ImageTestFile.pt.2.sm (3,33 MiB) descargado 1698 vez(es).
Mike Kaganski 20/4/2016 19:30:00, Davide Carpi 20/4/2016 19:04:00, Andrey Ivashov 17/5/2016 10:55:00
#62 Publicado: 20/4/2016 20:42:28
Mike Kaganski
Mike Kaganski
184 me gusta en 434 mensajes.
Test and report!
Thank you very much! It just works!!!
С уважением, Михаил Каганский
#63 Publicado: 21/4/2016 2:17:39
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
I want to remind you that we already have a function READRGB() which uses Mathcad style.
Smath opens RGB in the same style as Mathcad
This is MathcadFileAccess plugin opens.
Viacheslav,
Given that rendering capabilities of the image region were expanded, could you take a look at the READRGB() function and similar?
Currently it takes 6 times longer to read the image from file than to render it.. Is there an opportunity for a little performance bump? Maybe using the newly baked Entry[] variable could help...
#64 Publicado: 5/5/2016 12:54:32
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
I am thinking of adding suport for CorelDraw .cdr file.. Primarily for the very neat "smart drawing" tool it has. For those who does not know smart drawing is a pencil like tool that will take your rough scribble and transform it into a vector rectangle, line, triangle, circle etc.
Now question to you guys - are you aware of any other software besides CorelDraw that can do that?
#65 Publicado: 5/5/2016 17:36:59
kilele
kilele
134 me gusta en 397 mensajes.
- Ziteboard has a shape recognition feature and allows to export drawings for free.
- Inkscape has a line/freehand drawing tool which you can even adjust the amount of smoothing you want before you draw the line.
- Gimp has a plugin called "Smooth Path" which I've never tried.
#66 Publicado: 5/5/2016 20:47:45
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
- Ziteboard has a shape recognition feature and allows to export drawings for free. - very limited does not work oofline?
- Inkscape has a line/freehand drawing tool which you can even adjust the amount of smoothing you want before you draw the line. - does not recognize shapes
- Gimp has a plugin called "Smooth Path" which I've never tried. - does not recognize shapes
CorelDraw Essentials X6 is only $80 - reasonably priced.
#67 Publicado: 6/5/2016 8:15:28
kilele
kilele
Some more tools for you to investigate: microsoft onenote, grafio lite, sketchboard at sourceforge.net
Nice project to get started in programming. I guess that an easy way than using techniques like computer vision, learning machine, etc. could be a step to step menu guiding the user while he's drawing. Since you'd be drawing commands should have to be made by voice.
#68 Publicado: 10/5/2016 5:09:55
kilele
kilele
Coreldraw's smart drawing looks like a neat tool indeed.
Did Onenote work for you? The last version, for tablets at least, is said to support shape recognition.
#69 Publicado: 10/5/2016 11:31:18
What I don't understand, but I don't have to understand: why that "Image region"
persists with "Art drawing stuff" ... that you pay $ or do nothing ... instead of
working with "Engineering CAD tools" and many are freeware, damned advanced, can
save *.dxf [Autocad].
I wonder who cares "Art Drawing" in a math tool like Smath ?
#70 Publicado: 10/5/2016 11:59:12
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Hey guys lets not start another holy crusade here. Image region does dwg and dxf as well. And pixel perfect RGBA matrix rendering.
Kilele, I was on a quest to find perfect sketching tool for a while.. What I needed was to have software where I can pickup a (digital) pencil and draw freehand to get the creativity juices flowing. With its Smart Drawing CorelDraw works great for me.. better than anything else. I did not use One Note because it is broken on my PC. I do use CAD when I want to make some real sketches to scale, and will use CorelDraw for conceptual doodles (right now I am still using buebeam for that).
Which brings me to the point - .cdr is a blank file choice now. Since it is a proprietary file format it is rendered in SMath by saving a same named .svg, .png, or .pdf in either root folder of the .sm workbook or the "temp" folder in the AppData.
#71 Publicado: 16/5/2016 14:49:55
Grupo: Moderator
Alex, can you see this matrix in the image region?
mat(mat(251,250,229,128,182,185,196,251,246,210,254,160,242,197,251,223,236,254,212,164,211,251,214,188,77,152,254,253,251,195,202,56,96,248,254,251,214,190,42,91,254,254,251,223,237,197,235,254,254,251,210,254,254,254,254,254,8,7),mat(251,250,201,128,142,175,140,251,241,153,254,122,242,141,251,186,207,254,162,128,157,251,161,211,177,213,220,218,251,150,233,189,211,231,216,251,167,227,169,198,225,211,251,179,252,207,221,225,208,251,159,252,168,141,207,207,8,7),mat(251,250,179,106,93,173,74,251,237,95,233,87,242,85,251,155,170,248,100,100,75,251,110,240,254,213,146,134,251,108,254,254,243,175,130,251,120,254,254,230,161,124,251,131,254,211,185,160,121,251,109,249,118,42,129,123,8,7),1,3)
#72 Publicado: 16/5/2016 14:58:59
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Hope its not one of those hard to trace bugs that are hardware / OS dependent
M.render.sm (8,55 KiB) descargado 1500 vez(es).
#73 Publicado: 16/5/2016 15:29:20
Grupo: Moderator
Thank you! Solved, seems I was having a newer version installed (?)
Uninstalled and downloaded again, now it works :d
Andrey Ivashov 17/5/2016 11:07:00
#74 Publicado: 16/5/2016 15:34:08
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Good to hear!
To all - post examples of use for the RGBA rendering capability. I would love to see some practical use of the matrix rendering - right now I am not quite sure what else to do with it besides messing with test image files.
#75 Publicado: 16/5/2016 21:05:27
Alex,
Just the image, that should enable testing from A...Z, is it ?
#76 Publicado: 17/5/2016 8:03:34
Grupo: Moderator
Using latest Nightly Build of SMath Studio and the last beta of Custom Functions.
Alex, can you make the double-click feature enabled just on the canvas of the region? It is really annoying while trying to edit the math content
#77 Publicado: 17/5/2016 10:24:17
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Could you please provide an example? I have just opened my balloon test file and nothing happens if I double click anywhere on the region.. as it should be.
#78 Publicado: 17/5/2016 12:24:25
Grupo: Moderator
Not sure what happened... while editing the file for posting the screenshots the default viewer was launched several times, now I'm no more able to reproduce. Don't worry, if it will happens again I'll try to find the way to reproduce it.
#79 Publicado: 17/5/2016 12:35:27
Grupo: Super Administrator
Hello, Alex.
I've also reproduced it today but cannot say what exactly caused this. I've used many double-clicks on R, G and B variables inside the region and pressed Ctrl+C/V several times... First impression was that pressed Ctrl button broke the logic somehow.
Davide Carpi 17/5/2016 12:47:00
#80 Publicado: 17/5/2016 12:43:49
Grupo: Moderator
Found it! Seems related to the exceptions
1. Add a region in the canvas;
2. add in the placeholder something like mat(identity(3),identity(3),identity(3),1,3);
3. change one of the RGB channels with a number (e.g. 1) -> mat(identity(3),1,identity(3),1,3);
4. double-click will launch the image viewer;
BTW, you should propagate the evaluation exceptions to the user, currently you can't notice when something fails in the evaluation...
Andrey Ivashov 17/5/2016 13:38:00
