Special Plots On 2D Plot Bug
Special Plots On 2D Plot Bug - Special Plots do not appear when using "if...else" domain argument - Mensajes
#1 Publicado: 21/3/2022 12:00:29
Mr. Whiskers
Mr. Whiskers
0 me gusta en 6 mensajes.
I have found a low priority issue where special plots (e.g. text shown on the 2D plot) do not appear on the 2D plot when using an "if...else" domain definition. The Special Plots do show up if I use boolean domain definitions, however.
I have attached a sample file here that should make it clear.
I also tried submitting this to the bug tracker, but it appears I do not have the privileges to log into the bug tracker system.
Thank you!
SpecialPlotsBug.sm (8,83 KiB) descargado 1646 vez(es).
#2 Publicado: 21/3/2022 14:23:30
If you declare the system is exact Bolean,
set it exact from the onset plot 1
#3 Publicado: 21/3/2022 14:53:55
Grupo: Moderator
Thank you!
You can use cases() in Custom Functions Plugin for that purpose.
Plotting, solve(), roots(), FindRoot() and various commands may don't like if/else.
Sometimes an error can be fixed by using a line(), not in your example though.
Recursive functions doesn't solve when line() and cases() used both, etc etc.
These are bitter tricks/bugs, I tend to forgot them everytime.
After struggling a while however I remember the "correct usage".
#4 Publicado: 21/3/2022 18:30:37
Grupo: Moderator
Would be interesting, why if() is not defined by default as boolean expression just like cases().
Is there any use case, where the original if() is better than the one defined with cases()? If not, then I propose to include re-definition of if() in the custom functions plugin.
sergio 22/3/2022 5:48:00
#5 Publicado: 21/3/2022 20:20:41
Bolean bug(s) are user bug.
Many projects will accommodate either style if/else ... if/otherwise
A long suite of conditions is horror if/else.
Doctor your plot 1 as proposed, press F9
Integrate Discontinuous_1.sm (24,57 KiB) descargado 1615 vez(es).
Integrate Discontinuous.sm (36,51 KiB) descargado 1660 vez(es).
Integrate Discontinuous_2.sm (132,47 KiB) descargado 1652 vez(es).
#6 Publicado: 21/3/2022 21:57:44
Examine more Bolean applications.
Dolphin.sm (37,09 KiB) descargado 1689 vez(es).
#7 Publicado: 21/3/2022 22:21:45
Hi Martin. Yes. Here one: https://en.smath.com/forum/yaf_postsm34552_Custom-Functions-plugin.aspx#post34552
and here the Davide answer about that: https://en.smath.com/forum/yaf_postsm34559_Custom-Functions-plugin.aspx#post34559
I also remember some other about what complex could be the expressions in cases(), but can't found that.
sergio 22/3/2022 6:05:00
#8 Publicado: 22/3/2022 9:26:54
... doctored for convenience.
Observe collected plot, easy to manage.
SpecialPlotsBug DOCTORED.sm (10,86 KiB) descargado 1638 vez(es).
#9 Publicado: 22/3/2022 11:42:00
... you make Bolean algo style
for convenient command line.
