1 páginas (4 elementos)
Triangular Mesh for 3D plots - Mensajes
Hi. There are several variants for the triangular meshs. This is one.
pTriMesh.pdf (459,2 KiB) descargado 896 vez(es).
pTriMesh.sm (29,35 KiB) descargado 1555 vez(es).
Hi. Here are some notes about how the mesh is constructed. To include the missing vertices, they would have to be inserted at least twice, when drawing the diagonals. It could be done by constructing the mesh as it is, and instead of drawing the entire diagonal, to the center of the squares, but it could be a slow procedure. For another example, please see https://en.smath.com/forum/yaf_postsm74527_Offset-surface-creation.aspx#post74527
pTriMesh work.sm (28,8 KiB) descargado 1503 vez(es).
This other have the intesections as part of the mesh.
pTriMesh_v2.sm (48,39 KiB) descargado 1547 vez(es).
Hi. More general mesh utility, with a variable patern. Also, waterfall plots (matlab page here).
pWMesh.sm (193,8 KiB) descargado 1538 vez(es).
pWMesh.pdf (3,2 MiB) descargado 976 vez(es).
