[SS-2436] Boolean Operator using Text and Numbers
[SS-2436] Boolean Operator using Text and Numbers - Understanding if statements when using Boolean operators with text and numbers - Mensajes
#1 Publicado: 6/3/2017 18:01:32
Ryan Freund
Ryan Freund
20 me gusta en 339 mensajes.
Why is it that within an if statement I can use a Boolean equal sign to compare objects to a number, but if I try to compare numbers to text I get an error stating that the action could not be performed with text.
See attached.
Boolean Operator - Text and Number.sm (9,59 KiB) descargado 1309 vez(es).
#2 Publicado: 6/3/2017 22:51:13
Not sure what you are looking for ?
#3 Publicado: 6/3/2017 23:26:04
Ryan Freund
Ryan Freund
Ah yes, I should have been more specific.
It seems odd to me that the if you compare text to a number the Boolean decides that the text does not equal the number so it executes "as expected". However, if you compare a number to text there is an error thrown. Clearly the text is not the number so why not behave in the same manor?
Thanks for the response, btw.
#4 Publicado: 7/3/2017 7:01:20
Grupo: Moderator
Seems a bug to me. At first glance it happens only if the number in the comparison comes from el() and is not the first matrix element.
#5 Publicado: 7/3/2017 8:42:04
Few modules in this work sheet, may be useful.
Sorry : unrecorded source/originator.
Utilities Matrix IsArray.sm (20,24 KiB) descargado 1265 vez(es).
