Solve Function Question
Solve Function Question - Don't understand index required in the example - Mensajes
#1 Publicado: 26/5/2025 4:01:47
RegRetired
RegRetired
8 me gusta en 144 mensajes.
In the attached sm file, I am trying to find the roots, alpha, to a complex set of equations. To get the answer, I have to use the index 2 as noted. An image of the important part of the calculation is shown in this image.
Also, I cannot get any other root finding functions to work. I have added the maxima plugin, but that fails also. If there is a function not requiring the index that works, I would appreciate the help.
ALPHA LAMBDA WORKING.sm (99,81 KiB) descargado 1647 vez(es).
Thanks,
Reg
Reg CurryLoveland, CO
#2 Publicado: 26/5/2025 13:50:37
StvMath
StvMath
44 me gusta y 1 no me gusta en 76 mensajes.
The solve function finds two solutions for each combination of Rexp, RTexp etc., the first of which is always zero. Presumably you want the non-zero solution which is the second one found, hence the subscript 2.
You could also use the four-parameter version of solve; for example: solve(F(a),a,0.001,1) which will find solutions betwee 0.001 and 1.
francesco rapuano 26/5/2025 15:38:13
#3 Publicado: 26/5/2025 17:38:32
RegRetired
RegRetired
Thank you.👍
