Cephes Math Library
Cephes Math Library - Adds 78 special functions (Cephes Math Library 2.4, CALGO). - Mensajes
#21 Publicado: 18/8/2013 12:45:21
Grupo: Moderator
Updated. Well, the last time. I compiled plugin in the release configuration. Maybe this version will work. And show me the log file.
Much better now, yet still problems. Part of the functions now work and no side effenct so far.
Thank you for keep fighting!
Just to join Martin and to thank uni for his efforts
Here is my log file. It seems it is the same like Martin's. Unfortunately, some functions do not work, they are present in the list (like Bessel, Hankel, Airy) but they do not work.
log.txt (32,07 KiB) descargado 1504 vez(es).
#22 Publicado: 18/8/2013 13:53:53
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Thank you Martin, thank you Radovan.
It looks like the case was in the debug version of the plugin. Some functions do not work due to the fact that I have modified the code. Earlier, I used already compiled library. This is the first time I compiled it myself.
I will look for errors and make corrections. Please try 64bit version too.
#23 Publicado: 18/8/2013 16:20:52
Grupo: Moderator
I had to remove the EFI plugin in order to run the 64bit version, here is the cephes log
18.08.2013 22:03:49 [ERROR] [Plugin.Initialize()] ist keine zulässige Win32-Anwendung. (Ausnahme von HRESULT: 0x800700C1)
18.08.2013 22:03:49 [INFO ] [Plugin.Initialize()] Successfully. 0 functions loaded.
This is what the error message says:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.BadImageFormatException: Die Datei oder Assembly "file:///D:\Programme\SMath\SMathStudio_Desktop.exe" oder eine Abhängigkeit davon wurde nicht gefunden. Es wurde versucht, eine Datei mit einem falschen Format zu laden.
Dateiname: "file:///D:\Programme\SMath\SMathStudio_Desktop.exe"
bei System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
bei System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
bei System.Reflection.Assembly.LoadFrom(String assemblyFile)
bei ..(String , String )
bei ..(Object , EventArgs )
bei System.Windows.Forms.Timer.OnTick(EventArgs e)
bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Protokollierung der Assemblybindung ist AUS.
Sie können die Protokollierung der Assemblybindungsfehler aktivieren, indem Sie den Registrierungswert [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) auf 1 festlegen.
Hinweis: Die Protokollierung der Assemblybindungsfehler führt zu einer gewissen Leistungseinbuße.
Sie können dieses Feature deaktivieren, indem Sie den Registrierungswert [HKLM\Software\Microsoft\Fusion!EnableLog] entfernen.
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 2.0.0.0.
Win32-Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
SMathStudio_Desktop
Assembly-Version: 0.96.4909.6806.
Win32-Version: 1.1.26.0.
CodeBase: file:///D:/Programme/SMath/SMathStudio_Desktop_64.exe.
Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
#24 Publicado: 18/8/2013 22:55:36
Grupo: Moderator
Martin, try to remove mathlib.dll from the plugin folder. When the plugin is loading it tries to find the library. If not found, then it unloads library from the resources depending on the type of platform.
Martin Kraska 19/8/2013 10:40:00
#25 Publicado: 19/8/2013 10:39:19
Grupo: Moderator
Ok, I did this (and removed EFI).
Upon start of the 64bit version I get an error message.
Mostrar spoiler
and the log file has the contents:
Mostrar spoiler
I can recover from the error message with the button [continue].
Doing something simple like abs(i)= leads to german yellow error box saying something like "not a valid Win32 application, exception HRESULT: 0x800700C1"
Loading the cephes test sheet leads to a new error message, saying:
Mostrar spoiler
When I recover via [continue], then SMath tries to display the plugin loader, but fails to list what plugin would be required and then freezes (kill by Program manager required).
In order to go back to normal use of the 32bit version I have to remove the mathlib.dll again. Thus, for the normal user (unaware of plugin dirs and dlls) it is not safe to switch versions from time to time.
Also, you cannot run instances of SMath with different bitness at a time if they have the same settings directory.
#26 Publicado: 11/9/2016 14:02:10
Grupo: Moderator
Updated (project now can be build using Release Manager), but something wrong with Release Manager. Plugin can't load functions from the mathlib. Local version works fine.
#27 Publicado: 12/9/2016 6:14:28
Grupo: Moderator
Updated (Release Manager corrected, thanks to Andrey). Seems x64 version works.
Cephes Math Library. Functions.pdf (41,73 KiB) descargado 3120 vez(es).
frapuano 12/9/2016 8:26:00
#28 Publicado: 15/9/2016 9:54:01
Grupo: Moderator
Updated. At last both versions (x32 and x64) work well.
Davide Carpi 15/9/2016 10:16:00
#29 Publicado: 19/6/2020 3:47:30
Grupo: Moderator
Updated.
Changes:
- fixed error when freeing resources;
- refactored.
frapuano 19/6/2020 9:35:00
#30 Publicado: 9/7/2021 23:42:23
Grupo: Moderator
Plugin doesn't seem to evaluate functions.
Gives "domain: [#]" error, don't know the meaning.
#31 Publicado: 10/7/2021 1:26:36
Grupo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- refactored.
This error means that the second argument was out of bounds. The function checks the value of the arguments before calling.
Archivo no encontrado. Archivo no encontrado.
Computing elliptic integrals by duplication (Carlson).pdf (672,24 KiB) descargado 8089 vez(es).
Links:
1. Algorithm 577: Algorithms for Incomplete Elliptic Integrals (B. C. Carlson, Elaine M. Notis)
sergio 10/7/2021 4:57:00
