Cephes Math Library - Adds 78 special functions (Cephes Math Library 2.4, CALGO). - Mensajes
WroteWroteUpdated. Well, the last time. I compiled plugin in the release configuration. Maybe this version will work. And show me the log file.
Much better now, yet still problems. Part of the functions now work and no side effenct so far.
Thank you for keep fighting!
Just to join Martin and to thank uni for his efforts
Here is my log file. It seems it is the same like Martin's. Unfortunately, some functions do not work, they are present in the list (like Bessel, Hankel, Airy) but they do not work.
log.txt (32,07 KiB) descargado 1503 vez(es).
Вячеслав Мезенцев 18/8/2013 13:54:00
Thank you Martin, thank you Radovan.
It looks like the case was in the debug version of the plugin. Some functions do not work due to the fact that I have modified the code. Earlier, I used already compiled library. This is the first time I compiled it myself.
I will look for errors and make corrections. Please try 64bit version too.
WrotePlease try 64bit version too.
I had to remove the EFI plugin in order to run the 64bit version, here is the cephes log
18.08.2013 22:03:49 [ERROR] [Plugin.Initialize()] ist keine zulässige Win32-Anwendung. (Ausnahme von HRESULT: 0x800700C1)
18.08.2013 22:03:49 [INFO ] [Plugin.Initialize()] Successfully. 0 functions loaded.
This is what the error message says:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.BadImageFormatException: Die Datei oder Assembly "file:///D:\Programme\SMath\SMathStudio_Desktop.exe" oder eine Abhängigkeit davon wurde nicht gefunden. Es wurde versucht, eine Datei mit einem falschen Format zu laden.
Dateiname: "file:///D:\Programme\SMath\SMathStudio_Desktop.exe"
bei System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
bei System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
bei System.Reflection.Assembly.LoadFrom(String assemblyFile)
bei ..(String , String )
bei ..(Object , EventArgs )
bei System.Windows.Forms.Timer.OnTick(EventArgs e)
bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Protokollierung der Assemblybindung ist AUS.
Sie können die Protokollierung der Assemblybindungsfehler aktivieren, indem Sie den Registrierungswert [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) auf 1 festlegen.
Hinweis: Die Protokollierung der Assemblybindungsfehler führt zu einer gewissen Leistungseinbuße.
Sie können dieses Feature deaktivieren, indem Sie den Registrierungswert [HKLM\Software\Microsoft\Fusion!EnableLog] entfernen.
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 2.0.0.0.
Win32-Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
SMathStudio_Desktop
Assembly-Version: 0.96.4909.6806.
Win32-Version: 1.1.26.0.
CodeBase: file:///D:/Programme/SMath/SMathStudio_Desktop_64.exe.
Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
Вячеслав Мезенцев 18/8/2013 22:44:00
Martin, try to remove mathlib.dll from the plugin folder. When the plugin is loading it tries to find the library. If not found, then it unloads library from the resources depending on the type of platform.
Martin Kraska 19/8/2013 10:40:00
Ok, I did this (and removed EFI).
Upon start of the 64bit version I get an error message.
and the log file has the contents:
I can recover from the error message with the button [continue].
Doing something simple like abs(i)= leads to german yellow error box saying something like "not a valid Win32 application, exception HRESULT: 0x800700C1"
Loading the cephes test sheet leads to a new error message, saying:
When I recover via [continue], then SMath tries to display the plugin loader, but fails to list what plugin would be required and then freezes (kill by Program manager required).
In order to go back to normal use of the 32bit version I have to remove the mathlib.dll again. Thus, for the normal user (unaware of plugin dirs and dlls) it is not safe to switch versions from time to time.
Also, you cannot run instances of SMath with different bitness at a time if they have the same settings directory.
mscorlib
SMathStudio_Desktop
System
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
ioman
Assembly-Version: 0.96.4909.6802.
Win32-Version: 0.96.4909.6802.
CodeBase: file:///D:/Programme/SMath/ioman.DLL.
System.Windows.Forms.resources
Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
canvas
Assembly-Version: 0.96.4909.6803.
Win32-Version: 0.96.4909.6803.
CodeBase: file:///D:/Programme/SMath/canvas.DLL.
rview
Assembly-Version: 0.96.4909.6804.
Win32-Version: 0.96.4909.6804.
CodeBase: file:///D:/Programme/SMath/rview.DLL.
System.Xml
Win32-Version: 2.0.50727.5473 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
MathcadFileAccess
Assembly-Version: 1.0.4972.7682.
Win32-Version: 1.0.4972.7682.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/02a1c2c5-590e-46bb-bcf6-c87856a8b14b/1.0.4972.7682/MathcadFileAccess.dll.
NuLib
Assembly-Version: 1.63.4909.6802.
Win32-Version: 1.63.4909.6802.
CodeBase: file:///D:/Programme/SMath/NuLib.DLL.
customFunctions
Assembly-Version: 1.0.4902.41872.
Win32-Version: 1.0.4902.41872.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.0.4902.41872/customFunctions.dll.
FIRFilterDesign
Assembly-Version: 1.0.4972.7542.
Win32-Version: 1.0.4972.7542.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/191f7c7a-6b6e-4af0-8bb7-c7a202d59cd4/1.0.4972.7542/FIRFilterDesign.dll.
3DPlotRegion
Assembly-Version: 0.1.4972.7309.
Win32-Version: 0.1.4972.7309.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/2427d808-1e5e-4ae0-88bf-bc271664a3ab/0.1.4972.7309/3DPlotRegion.dll.
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
ComboBoxRegion
Assembly-Version: 0.1.4895.5243.
Win32-Version: 0.1.4895.5243.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/28ea70bd-1dee-4200-b2e1-1d53d5832487/0.1.4895.5243/ComboBoxRegion.dll.
DotNumerics
Assembly-Version: 1.1.4972.7520.
Win32-Version: 1.1.4972.7520.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/2a69099d-3185-4ea7-a130-65f2bf94c8d6/1.1.4972.7520/DotNumerics.dll.
MapleWrapper
Assembly-Version: 1.0.4972.7570.
Win32-Version: 1.0.4972.7570.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.0.4972.7570/MapleWrapper.dll.
ICSharpCode.SharpZipLib
Assembly-Version: 0.86.0.518.
SMathFinancials
Assembly-Version: 1.0.4928.30282.
Win32-Version: 1.0.4928.30282.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/36acfa39-f2ec-4733-9b68-6f96426f672a/1.0.4928.30282/SMathFinancials.dll.
HyperlinkRegion
Assembly-Version: 0.1.4970.542.
Win32-Version: 0.1.4970.542.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/0.1.4970.542/HyperlinkRegion.dll.
MatlabCppMathLibrary
Assembly-Version: 1.0.4979.2396.
Win32-Version: 1.0.4979.2396.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4c2faab1-4d93-4904-8d88-a4e21512d179/1.0.4979.2396/MatlabCppMathLibrary.dll.
mscorlib.resources
DataExchange
Assembly-Version: 1.0.4909.14713.
Win32-Version: 1.0.4909.14713.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.4909.14713/DataExchange.dll.
Ionic.Zip
Assembly-Version: 1.9.1.8.
Win32-Version: 1.9.1.8.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.4909.14713/Ionic.Zip.dll.
NonlinearSolvers
Assembly-Version: 1.0.9999.5.
Win32-Version: 1.0.9999.5.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/618b7e96-330a-406a-b055-9e577672f0b8/1.0.9999.5/NonlinearSolvers.dll.
ClosedXML
Assembly-Version: 0.68.1.0.
Win32-Version: 0.68.1.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/ClosedXML.dll.
DocumentFormat.OpenXml
Assembly-Version: 2.0.5022.0.
Win32-Version: 2.0.5022.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/DocumentFormat.OpenXml.DLL.
System.Core
Assembly-Version: 3.5.0.0.
Win32-Version: 3.5.30729.5420 built by: Win7SP1.
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll.
WindowsBase
Assembly-Version: 3.0.0.0.
Win32-Version: 3.0.6920.5453 built by: Win7SP1GDR.
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll.
XlsxImportExport
Assembly-Version: 1.0.4909.14933.
Win32-Version: 1.0.4909.14933.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/XlsxImportExport.dll.
ImageRegion
Assembly-Version: 1.0.4906.39296.
Win32-Version: 1.0.4906.39296.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.4906.39296/ImageRegion.dll.
StatisticalTools
Assembly-Version: 1.0.4902.38391.
Win32-Version: 1.0.4902.38391.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/76f6e9f5-ac86-4ffb-9e4d-284c8daecaf9/1.0.4902.38391/StatisticalTools.dll.
AlgLib
Assembly-Version: 1.0.4972.7412.
Win32-Version: 1.0.4972.7412.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/8e40b49c-3681-4332-903d-751303860e7b/1.0.4972.7412/AlgLib.dll.
CheckBoxRegion
Assembly-Version: 1.0.4895.5188.
Win32-Version: 1.0.4895.5188.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/aeb799ab-3afc-4a82-8f44-27d03df672ca/1.0.4895.5188/CheckBoxRegion.dll.
ZedGraphRegion
Assembly-Version: 0.1.4906.20456.
Win32-Version: 0.1.4906.20456.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/b0e7602f-c9d4-4e6c-b6f1-087e4c6e8915/0.1.4906.20456/ZedGraphRegion.dll.
CephesMathLibrary
Assembly-Version: 1.0.4978.35158.
Win32-Version: 1.0.4978.35158.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/b50f73cb-c149-47b1-952a-f95b0c32d6d4/1.0.4978.35158/CephesMathLibrary.dll.
mathlib
Assembly-Version: 1.0.4978.35138.
Win32-Version: .
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/b50f73cb-c149-47b1-952a-f95b0c32d6d4/1.0.4978.35158/mathlib.dll.
msvcm90
Assembly-Version: 9.0.30729.6161.
Win32-Version: 9.00.30729.6161.
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll.
XYPlotRegion
Assembly-Version: 0.1.4911.35572.
Win32-Version: 0.1.4911.35572.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/c12231ec-4873-43c1-a7d0-a167ebd17066/0.1.4911.35572/XYPlotRegion.dll.
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
GPCWrapper
Assembly-Version: 1.0.4931.29227.
Win32-Version: 1.0.4931.29227.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f01/1.0.4914.35302/GPCWrapper.dll.
ODESolvers
Assembly-Version: 1.0.4975.7557.
Win32-Version: 1.0.4975.7557.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/ODESolvers.dll.
HTMLFileType
Assembly-Version: 1.12.4909.6752.
Win32-Version: 1.12.4909.6752.
CodeBase: file:///D:/Programme/SMath/plugins/HTMLFileType.dll.
ImageFileType
Assembly-Version: 1.8.4909.6757.
Win32-Version: 1.8.4909.6757.
CodeBase: file:///D:/Programme/SMath/plugins/ImageFileType.dll.
PictureRegion
Assembly-Version: 1.9.4909.6762.
Win32-Version: 1.9.4909.6762.
CodeBase: file:///D:/Programme/SMath/plugins/PictureRegion.dll.
PlotRegion
Assembly-Version: 1.8.4909.6768.
Win32-Version: 1.8.4909.6768.
CodeBase: file:///D:/Programme/SMath/plugins/PlotRegion.dll.
SMathFileType
Assembly-Version: 1.8.4909.6774.
Win32-Version: 1.8.4909.6774.
CodeBase: file:///D:/Programme/SMath/plugins/SMathFileType.dll.
SpecialFunctions
Assembly-Version: 1.10.4909.6779.
Win32-Version: 1.10.4909.6779.
CodeBase: file:///D:/Programme/SMath/plugins/SpecialFunctions.dll.
TextRegion
Assembly-Version: 1.9.4909.6785.
Win32-Version: 1.9.4909.6785.
CodeBase: file:///D:/Programme/SMath/plugins/TextRegion.dll.
ViewerFileType
Assembly-Version: 1.0.4909.6791.
Win32-Version: 1.0.4909.6791.
CodeBase: file:///D:/Programme/SMath/plugins/ViewerFileType.dll.
XMCDFileType
Assembly-Version: 1.11.4909.6797.
Win32-Version: 1.11.4909.6797.
CodeBase: file:///D:/Programme/SMath/plugins/XMCDFileType.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
mscorlib
SMathStudio_Desktop
System
System.Drawing
ioman
canvas
rview
System.Xml
MathcadFileAccess
NuLib
customFunctions
FIRFilterDesign
3DPlotRegion
System.Design
ComboBoxRegion
DotNumerics
MapleWrapper
SMathFinancials
HyperlinkRegion
mscorlib.resources
DataExchange
Ionic.Zip
NonlinearSolvers
ClosedXML
System.Core
WindowsBase
XlsxImportExport
ImageRegion
StatisticalTools
AlgLib
CheckBoxRegion
ZedGraphRegion
CephesMathLibrary
mathlib
Win32-Version: .
msvcm90
XYPlotRegion
GPCWrapper
ODESolvers
HTMLFileType
ImageFileType
PictureRegion
PlotRegion
SMathFileType
SpecialFunctions
TextRegion
ViewerFileType
XMCDFileType
Zum Beispiel:
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] phi(2) - [ u,k ] Amplitude of jacobian elliptic functions phi(u,k) of real arguments.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] LegendreP(3) - [ x,n,k ] Legendre's canonical incomplete elliptic integral of the third kind with real arguments.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] LegendrePc(2) - [ n,k ] Legendre's complete elliptic integral of the third kind with real arguments.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] LegendrePc1(2) - [ n,k ] Associated Legendre's complete elliptic integral of the third kind with real arguments.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Rf(3) - [ x,y,z ] Carlson's incomplete elliptic integral of the first kind with real arguments.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Rd(3) - [ x,y,z ] Carlson's incomplete elliptic integral of the second kind with real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Rj(4) - [ x,y,z,p ] Carlson's incomplete elliptic integral of the third kind with real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Dawson(1) - [ x ] Dawson's Integral of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] FresnelC(1) - [ x ] Fresnel integral C(x) of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] FresnelS(1) - [ x ] Fresnel integral S(x) of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] dilog(1) - [ x ] Dilogarithm function of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Zeta(1) - [ x ] Riemann zeta function of real argument. x must be positive
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Zeta2(2) - [ x,q ] Riemann zeta function of two arguments. It is the sum, for k integer ranging from 0 to infinity, of (k+q)^-x where q is a positive integer and x > 1.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Ei(2) - [ n,x ] Exponential integral Ei. n in an integer, x is real.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Si(1) - [ x ] Sine integral of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Ci(1) - [ x ] Cosine integral of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Shi(1) - [ x ] Hyperbolic sine integral of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Chi(1) - [ x ] Hyperbolic cosine integral of real argument.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Plm(3) - [ l,m,x ] First kind Legendre polynomials and associated functions of degree l and integer order m. Plm(l,m,x) = (-1)^m (1-x^2)^(m/2) d^m( Pn(n,x) )/dx^m where l and x must be real and Pn(n,x) is the Legendre polynomial.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Qlm(3) - [ l,m,x ] Second kind Legendre functions of degree l, integer order m and argument 0<=x<1.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] plm(3) - [ l,m,x ] Normalized first kind Legendre polynomials and associated functions of integer degree l and integer order m.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Ylm(4) - [ l,m,theta,phi ] Spherical harmonic of integer degree l, integer order m, latitude theta in [-PI,PI] and longitude phi.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Yl(3) - [ l,theta,phi ] Sequence of spherical harmonic of integer degree l, integer order m=0..l, latitude theta in [-PI,PI] and longitude phi.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] round(1) - [ x ] Round real x to nearest or even integer number.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] signum(1) - [ x ] Sign of x.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] csgn(1) - [ x ] Complex sign of x.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] sfact(1) - [ n ] Semifactorial of integer n.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] mask(1) - [ x ] Masks and unmasks the partial loss of precision error. If called with x = 0 that error message is disabled, if called with x != 0 that error message is enabled. Returns the previous state; default is unmasked.
19.08.2013 16:12:26 [INFO ] [Plugin.Initialize()] Successfully. 78 functions loaded.
bei System.Windows.Forms.Form.OnLoad(EventArgs e)
bei System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
bei System.Windows.Forms.Control.CreateControl()
bei System.Windows.Forms.Control.WmShowWindow(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
mscorlib
SMathStudio_Desktop
System
System.Drawing
ioman
canvas
rview
System.Xml
MathcadFileAccess
NuLib
customFunctions
FIRFilterDesign
3DPlotRegion
System.Design
ComboBoxRegion
DotNumerics
MapleWrapper
SMathFinancials
HyperlinkRegion
mscorlib.resources
DataExchange
Ionic.Zip
NonlinearSolvers
ClosedXML
System.Core
WindowsBase
XlsxImportExport
ImageRegion
StatisticalTools
AlgLib
CheckBoxRegion
ZedGraphRegion
CephesMathLibrary
mathlib
Win32-Version: .
msvcm90
XYPlotRegion
GPCWrapper
ODESolvers
HTMLFileType
ImageFileType
PictureRegion
PlotRegion
SMathFileType
SpecialFunctions
TextRegion
ViewerFileType
XMCDFileType
Zum Beispiel:
mscorlib
SMathStudio_Desktop
System
System.Drawing
ioman
canvas
rview
System.Xml
MathcadFileAccess
NuLib
customFunctions
FIRFilterDesign
3DPlotRegion
System.Design
ComboBoxRegion
DotNumerics
MapleWrapper
SMathFinancials
HyperlinkRegion
mscorlib.resources
DataExchange
Ionic.Zip
NonlinearSolvers
ClosedXML
System.Core
WindowsBase
XlsxImportExport
ImageRegion
StatisticalTools
AlgLib
CheckBoxRegion
ZedGraphRegion
CephesMathLibrary
mathlib
Win32-Version: .
msvcm90
XYPlotRegion
GPCWrapper
ODESolvers
HTMLFileType
ImageFileType
PictureRegion
PlotRegion
SMathFileType
SpecialFunctions
TextRegion
ViewerFileType
XMCDFileType
Zum Beispiel:
Вячеслав Мезенцев 20/8/2013 6:33:00
Updated (project now can be build using Release Manager), but something wrong with Release Manager. Plugin can't load functions from the mathlib. Local version works fine.
Updated (Release Manager corrected, thanks to Andrey). Seems x64 version works.
Cephes Math Library. Functions.pdf (41,73 KiB) descargado 3120 vez(es).
frapuano 12/9/2016 8:26:00
Updated. At last both versions (x32 and x64) work well.
Davide Carpi 15/9/2016 10:16:00
Updated.
Changes:
- fixed error when freeing resources;
- refactored.
Changes:
- refactored.
frapuano 19/6/2020 9:35:00
Plugin updated.
Changes:
- refactored.
This error means that the second argument was out of bounds. The function checks the value of the arguments before calling.
Archivo no encontrado. Archivo no encontrado.
Computing elliptic integrals by duplication (Carlson).pdf (672,24 KiB) descargado 8088 vez(es).
Links:
1. Algorithm 577: Algorithms for Incomplete Elliptic Integrals (B. C. Carlson, Elaine M. Notis)
sergio 10/7/2021 4:57:00
