Strange unit problem - Unnecessary parts in unit pop up - Mensajes
rho has unit kg/m3
g has unit m/s^2
H has unit mm
P gets unit m3/m3*Pa if I try to change the default unit to Pa. It is in fact Pa because the volumes cancel out each others but my document becomes very uncomprehensive to read as this happens with other multiplications too. How to get the m3/m3 dropped out, I couldn't find a working solution?
B.R. Timo
WroteCalculating pressure from P:=rho*g*H, where
rho has unit kg/m3
g has unit m/s^2
H has unit mm
B.R. Timo
Are you sure you have entered units correctly?
Result is already Pascal in my calculation.
I tried to take a screen capture but couldn't figure out how to get it here, Ctrl+V does not work and I don't kow how to proceed with URL to get something here. However, the problem is simple, how to remove away the unity part or remaining units.
B.R. Timo
you were right, I had rho in kg/m3 instead of kg/m^3. A typo which was quite difficult to recognize. It would be beneficial to be able to add a capture snippet like you had. How do you make that?
B.R. Timo
WroteHi again,
B.R. Timo
So it was a typo then, easy to miss hard to find.
You can capture image, save it and upload to SMath forum with this.
WroteWroteHi again,
B.R. Timo
Or post the SM file in the same fashion
