1 páginas (7 elementos)
new version errors - Mensajes
Hello
Since I tried to install the new version I get the following error
I have reinstalled version 4909 but still appear LoaderExcepstions errors at startup and the snippets are not users / local / programs ... they are in the folder (x86) Installation Smath
thanks
thanks
I can't work with matrix function
I can´t do that, the same error with matrix
I'm working with 4909 version, but it occurs since I tried install 5146
My windows is W7 professional /64
Ok...
I can suggest you only to create a simple file to post here or to send an e-mail to the developper with the file (sometimes the bug comes from other functions/plugins/settings).
As additional hint you can try to delete the "%APPDATA%\SMath\extensions\plugins" folder and the "Program Files(x86)\SMath\Plugins" folders before installing the 5146 version...
http://en.smath.info/forum/yaf_postst2112_-SOLVED--HRESULT--0x800700C1.aspx
the same error, ok
SOLVED, unnistall with GEEKS, now it works fine with 4909 version
thanks
the same error, ok
thanks
This issue appeared because of unmanaged Win32 (x86) plug-in installed for 64-bit platform. All you need to do to fix this issue - to close SMath Studio and remove all plug-ins installed before.
This was found by uni (thank you!) and together we found a permanent solution.
This will not happen anymore with next version of SMath Studio (plan to release it before next week).
A 4 usuarios les gustó este mensaje
IVR 8/2/2014 4:21:00, Вячеслав Мезенцев 8/2/2014 5:09:00, Davide Carpi 8/2/2014 6:52:00, ioan92 8/2/2014 14:53:00
![2014-02-04 12_34_12-SMath Studio Desktop - [Page1_].png](/es-ES/files/Download/NFd48o/2014-02-04-12_34_12-SMath-Studio-Desktop---[Page1_].png)
