NonlinearSolvers plugin
NonlinearSolvers plugin - BDQRF, Bisection, Brent's, Broyden's, Newton-Raphson, Ridder's, Secant, Homotopy - Mensajes
#161 Publicado: 9/3/2014 14:39:32
Grupo: Moderator
password for the Nonlinear Solvers plugin?
http://en.smath.info/forum/yaf_postsm10204_NonlinearSolvers-plugin--root-finding-methods--BETA-optimization-algorithms.aspx#post10204
ioan92 9/3/2014 14:45:00, Davide Carpi 10/3/2014 6:32:00
#162 Publicado: 10/3/2014 6:40:36
Grupo: Moderator
plugin's password added in the first post.
Best regards,
Davide
#163 Publicado: 31/8/2014 14:05:55
Grupo: Moderator
Thank you Martin,
you are right, I'll try to fix it...
This seems to be a matter of the perturbation size.
Jacobian.CD.sm (14,92 KiB) descargado 1607 vez(es).
Davide Carpi 1/9/2014 3:14:00
#164 Publicado: 3/3/2016 15:03:51
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346, SMath Studio 0.97.5737, SMath Studio 0.98
- Unknowns() now can be used inside functions (will returns 0 if no unknowns are found, instead of an error message);
- version numbering switched to 1.1.* to made easier to publish updates for different SS versions (next milestone: 1.2.*);
- password no longer required for those SS versions;
Radovan Omorjan 3/3/2016 15:18:00, sergio 3/3/2016 15:36:00
#165 Publicado: 7/4/2016 15:45:39
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
Hello Davide,
I am somewhat confused why FindRoot() cannot solve this equation. Am I doing something incorrectly?
It works just fine for some other equations..
Thanks!
FindRootCannotSolve.sm (4,59 KiB) descargado 1520 vez(es).
#166 Publicado: 7/4/2016 16:10:06
Grupo: Moderator
Hello Alex,
I cannot reproduce... do you have Maxima or some other plugin that may cause the issue?
#167 Publicado: 7/4/2016 16:18:09
Grupo: Moderator
It works for me. The same was mentioned some time ago here. It seems that some plugin is making trouble. I do not know which one.
#168 Publicado: 7/4/2016 17:03:40
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Omorr, Davide:
- Uninstalling Maxima plugin did nothing
- Clean install of stable 0.98 SMath Studio solved the issue. Now I just need to find what other plugin is wreaking havoc there..
Thank you
Oscar Campo 7/4/2016 18:28:00
#169 Publicado: 7/4/2016 22:57:46
Maths are unitless, therefore plot first the generatrix
to discover the function has no root(s). If you fabricate
with a unit system, you will have no plot. That's what I
call "invisible project"
#170 Publicado: 7/4/2016 23:01:10
... the other point is that Smathh is too granular to
reveal the Gaussian part of the function.
#171 Publicado: 7/4/2016 23:16:56
Mike Kaganski
Mike Kaganski
184 me gusta en 434 mensajes.
You make a wrong point here. You prefer to avoid using units in your sheets, and that's your right; but declaring that units are inappropriate (as you do now and again) is spreading FUD. Using units is a great feature of SMath (that is optional, so that you may choose to work as you like), but your unawareness of ways to take advantage from using units while keeping ability to, e.g., plotting, doesn't mean that it's good to state such bold claims (insted, you could simply create a new thread in "Questions" and ask others how to plot while using units).
Second, the function itself doesn't have roots, but original poster looked not for equation f(x)=0, but for f(x)=n, which is f(x)-n=0.
Third, you mistakingly put square for pi (it was meant for seconds, not for pi - if you used units, you would katch this, because the result would arrive in s*Pa).
С уважением, Михаил Каганский
#172 Publicado: 7/4/2016 23:54:08
... maybe that's what you had 4800481^2 instead of
4800481 m^2... just different scale plot. Whatever,
the negative branch has two symmetric complex roots.
#173 Publicado: 8/4/2016 0:13:20
Maths are unitless, end of it.
It would be fine in Smath if units would be decoration
but it's not in Smath 5346. From what Andery replied to
me, new versions have decoration style like Mathcad 11.
What do you put as units in Fourier, Laplace ...
In the Legendre Quadraature [Reconciliation] just posted
What's the unit of the cumulative integral ?
Answer: user "UnitGraphic".
So, we live it here.
Cheers, Jean
#174 Publicado: 8/4/2016 0:30:31
Mike Kaganski
Mike Kaganski
Please, don't multiply the offtopic here.
http://twt.mpei.ac.ru/ochkov/Unit_MC_MP/Unit_MC_MP_eng.htm
#175 Publicado: 8/4/2016 17:32:00
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
Jean,
You tried really hard on the Mathcad forums to preach the same thing and was a huge detractor to your work ... which is quality collaboration and maths.
Now, your preaching about graphing ... that is something worth "harping" on!
#176 Publicado: 9/4/2016 1:31:42
Quite right, the debate lasted for a while in the Mathsoft Collaboratory.
I defeated my detractors twice and for ever in this Colaboratory:
1. I put units in the Reynolds number [unitless] but got result that
none could decipher, even Mathsoft.
2. Doing some Plank physics, same thing: not decipherable.
The best was that no collab [to my recollection] posted advanced problems
with units. Use units in your profit but make sure you check unitless.
Units system is for personal use at arithmetic maths level.
Cheers, Jean
#177 Publicado: 9/9/2016 16:41:23
Grupo: Moderator
The Taylor() function throws the error message "Specify variable"
How am I expected to do this?
#178 Publicado: 9/9/2016 17:39:24
As it looks Martin, "Taylor" is by default.
#179 Publicado: 9/9/2016 18:54:26
Grupo: Moderator
You assigned a wrong value for the 2nd argument, "2:variable".
#180 Publicado: 9/9/2016 20:15:05
Grupo: Moderator
Hm, don't understand. For univariate expressions, the second argument is the development point.
For multivariate expressions, I would expect that I have to specify the independent variable and the development point.
In Maxima (not working in newer versions of SMath) it looks like this:
With your Taylor, I have this:
Sorry, I don't understand the result.
Analysis.sm (28,83 KiB) descargado 1603 vez(es).
