Issue in SmathStudio with "Solve" - For a long time I can't solve the problem in this program, I can't find the roots - Mensajes
Project
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.sm (1,44 MiB) descargado 1284 vez(es).
Please help, I know you can
WroteFor a long time I can't solve the problem in this program, I can't find the roots
The first error message is in Function_Prop
It says "must be a real number" ?
WroteThe first error message is in Function_Prop
... collapsed area are locked ! password.
WroteWroteThe first error message is in Function_Prop
Password 2153
But it`s not effect to my Issue
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.sm (1,44 MiB) descargado 1298 vez(es).
WroteIt`s file without first error, you can use it.
... does not either SS 6179.
You may replace Function_prop(P,T,M) by the Spline Matrix
Collapsed in red ... try some suite from there.
Watch unit system [not my cup of tea !]
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (1).sm (1,52 MiB) descargado 1259 vez(es).
Still red top2bottom
As it looks, you are attempting to integrate kg/m³ over 'p'
for the given 293 °K ... done otherwise finite differences.
In your solve block, vary many things are constants that could
be simplified but so many are undefined.
What should this solve bloc should do wrt the integration ?
find an intersection wrt some 'P' or else ?
The meaning of the cumulative integration reads like this:
"for °K 293, accumulate the kg/m³ over the 'p' range'
In other words: the cumulative mass-flow kg/m³over 'p' range
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (1).sm (1,53 MiB) descargado 1261 vez(es).
WroteWroteIt`s file without first error, you can use it.
I don't understand you. What should I do? Or, if You can, please correct it
This is the correct response to the variable that should be obtained in the Solve function
Use the Spline Matrix in lieu
I understand nothing in there.
Hope Collabs read and have some ideas !
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (20200312).sm (1,54 MiB) descargado 1293 vez(es).
WroteFunction_prop(P,T,M) does not work.
I don`t understand too. May be anyone have any idea?
WroteWroteFor a long time I can't solve the problem in this program, I can't find the roots
I fixed Function_Prop using InterpBilinear() from the Statistical Tools plugin. Note that the definition without line operator behaves buggy, because you even won't get the usual storage preview when hovering over the definition. This is strange and indicates something really bad under the hood.
Yet fixing the function doesn't solve any of the problems downstream. But given the strange error messages and bugs I'd say build 7251 can't be used safely anyways.
BTW, instead the if-else cascades I'd recommend using the selection index as index of a vector of options.
Raschet%20propusknojj%20sposobnosti%20truboprovoda%20s%20drosselem%20na%20vykhode_Kr.sm (1,44 MiB) descargado 1372 vez(es).
WroteWroteWroteFor a long time I can't solve the problem in this program, I can't find the roots
Perfect, may be you can solve "SOLVE" function in this program???
WrotePerfect, may be you can solve "SOLVE" function in this program ???
1. Up to this point: NO ... μ.др is undefined
2. If μ.др has a value: plug it in this document.
3. Please, don't re-post your original, so I can do more
from this document.
4. Units don't match in this project.
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (20200314).sm (1,52 MiB) descargado 1241 vez(es).
Define the base viscosity μ.др
The complex term is most puzzling ?
Raschet propusknojj [20200315].sm (1,52 MiB) descargado 1040 vez(es).
Wrote... look closely at the point we are.
Sorry. I understand you, I didn’t write it down. instead of μ.др . -> μ.тр
WroteSorry. I understand you, I didnât write it down. instead of μ.Ð´Ñ . -
... now that we have the base viscosity, we can plot/tabulate "Bloc".
From there, given some value in "Bloc" we can solve for the pressure
that creates this value .
Cheers ... jean
Does it make you progress in your project ?
Raschet propusknojj [20200316].sm (1,55 MiB) descargado 999 vez(es).
WroteWroteSorry. I understand you, I didnât write it down. instead of μ.Ð´Ñ . -
Cheers ... jean
The answer does not match, it might be better if I attach a file from MathCad. I have to translate the program from MathCad to SmathStudio, but sometimes I get errors like this.
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.xmcd (487,33 KiB) descargado 1291 vez(es).
Here is the answer, sorry, that in Russian
WroteI have to translate the program from MathCad to SmathStudio
... then check if the "Bloc" you have constructed is OK.
Tabulate the Mathcad "Bloc" that you have translated Smath.
My working Mathcad is 11 not connected to Internet,
My XP Pro. has no AV . If the two MCD/Smath blocs don't
agree/tabulate same: then your translation is in doubt.
I can't help more from so much not clear.
Check with Viacheslav, he is with MCD ... Maybe Radovan too.
Cheers, best ... Jean
