differential equations - solve differential equations - Mensajes
If you can please explain the various steps to be able to solve the differential equation in the picture.
I am interested in deriving the function phi (t), what do you need to know to solve the differential equation?
Thanks for your patience
Documento2 DE [explain more] (25).sm (48,29 KiB) descargado 1177 vez(es).
Wrotesorry but I have practically no experience with this program and I find it difficult to understand the functions.
T
The setup to numerical DE solver is same as Mathcad,
even superior as it takes the parameters as vector.
Use p[1,2,3] for those parameters.
Up to what you proposed before: you don't have a DE
Those parameters are non-sense as they send the system in the zillion domain. Get that DE from the teacher, a bit of abstract would help.
Documento2 DE [explain more] (25).sm (71,7 KiB) descargado 1156 vez(es).
Wrote...
Hi. Usually we want know the ode and it's initial conditions. In your case you have boundary conditions, which can be solved by the shooting method.
Hope this helps.
motocicleta.sm (48,71 KiB) descargado 1339 vez(es).
motocicleta.pdf (203,43 KiB) descargado 864 vez(es).
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
WroteMy initial conditions are:
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
For a Cauchy problem it's more easy.
motocicleta with IC.sm (37,14 KiB) descargado 1328 vez(es).
motocicleta with IC.pdf (136,74 KiB) descargado 877 vez(es).
regards
1. What maths are given/invented: a formula ?
2. From that formula, what is next
So, you have a formula and an objective project,
i.e: a pretty short work sheet not yet circular in the blue.
WroteThis is an offer ... accept/reject ... go back to "square zero"
I appreciate the advice. I'm trying to learn
WroteI appreciate the advice. I'm trying to learn
Just give the formula that you were given.
or make an image from source ... learning is after.
These two examples are Cauchy integration. They have no formal symbolic.
A discrete integration is possible via the module rkf4(y0,x0,x1,n,f).
From there: easy to get the discrete derivative.
ODE Cauchy Project.sm (27,38 KiB) descargado 1369 vez(es).
I tried using Simpson and Romberg's recursive methods, but without getting a solution.
Where am I wrong?
PROJECT.sm (69,12 KiB) descargado 1384 vez(es).
WroteHi, sorry if I bother you again. I'm trying to integrate a function, the function in question is psi''(t) in order to derive psi'(t).
You have phi in your document ... psi is a built-in function.
So, if phi''(t) is the 2nd derivative ... then the derivative
is simply the integral. To expedite fast: done discrete.
If you have questions: please re-post this document.
PROJECT [1].sm (30,82 KiB) descargado 1141 vez(es).
WroteYou have phi in your document
.... in fact you have PSI''(t).
Maple does not find an explicit integral.
PROJECT [1].sm (21,91 KiB) descargado 1153 vez(es).
Where am I wrong?
Hi. You can use any Runge Kutta solver for integration.
Also, you can use SMath int procedure, but it's very (very) slow:
For the theory, remember that you can integrate (with definite integrals) both sides of an equation and get an equality too, which don't work with derivatives.
PROJECT.sm (74,9 KiB) descargado 1396 vez(es).
But now I can't calculate the ratio in the picture.
The error says, "The matrix must be square"
PROJECT.sm (57,24 KiB) descargado 1380 vez(es).
WroteHi, I have calculated the function psi '(t) through dn_GearsBDF.
Result from numerical ODE solvers is a data set.
Generate an interpolation scalar to 'x' ... then plot.
@ the end of the document ... more questions: -this one.
PROJECT (1).sm (74,9 KiB) descargado 1372 vez(es).
