h(p1, p2) implicit plot
h(p1, p2) implicit plot - Why I can not create it? - Mensajes
#1 Publicado: 19/6/2024 18:34:29
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
2RegP-Ideal-Cool_Prop.sm (82,18 KiB) descargado 1643 vez(es).
#2 Publicado: 22/7/2024 14:59:18
pepperyalready
pepperyalready
1 me gusta en 1 mensajes.
Implicit.pngscratch geometry dash
The graph you've provided seems to show a relationship between two pressures 𝑝1and 𝑝2, with annotations related to efficiency calculations.
Axes:𝑝1 on the x-axis (measured in atm). 𝑝2 on the y-axis (measured in atm).
Curves: Different colored curves (red, blue, and green) that might represent different states or processes in a thermodynamic cycle or system, such as isobars, isotherms, or other state transitions.
Water/Steam Cycle: Given the mention of "WaterSteame Pro," this graph might be related to a water/steam cycle analysis, such as a Rankine cycle or steam turbine efficiency calculation.
Efficiency (𝜂): The efficiency calculations likely relate to the performance of a particular component or the overall system under different pressures and temperatures.
The mention of "points > 20 - problems" suggests there might be issues with the data points or calculations when exceeding a certain number of data points.
Valery Ochkov 22/7/2024 17:02:00
#3 Publicado: 24/7/2024 13:29:16
Hi. You can use the Draghilev's method for parametrize a curve.
2RegP-Ideal-Cool_Prop (1).sm (82,56 KiB) descargado 1575 vez(es).
2RegP-Ideal-Cool_Prop (1).pdf (317,07 KiB) descargado 944 vez(es).
Valery Ochkov 24/7/2024 14:02:00, Вячеслав Мезенцев 24/7/2024 15:55:00
#4 Publicado: 5/8/2024 13:51:05
Valery Ochkov
Valery Ochkov
My solution
