1 páginas (4 elementos)
Excel Table - Add an table of excel - Mensajes
Hi there! I am newbie in Smath, and I want to add an excel table but, when I take a screenshot, this image looks a bit pixelated, anyway, I know that with a code I will be able to add this table, but I don't know how. I hope you can help me.
There is a tool SMath Matrix editor for windows as far as I remember.
Excel spreadsheet could be copied from excel and pasted into it as SMath matrix.
Than that matrix can be shown as a table region.
There is also xlsx import plugins, they directly get tables from excel files.
Than table region solution again.
If it is not proprietary data, attaching it to this topic could help you faster.
Someone shall show you how to do it fast and properly.
Hi! thanks for your answer, I install the xls extension... I wanna add this table of excel... If u can help me it could be very usefull.
DensidadMaxMin.xlsx (14,07 KiB) descargado 992 vez(es).
WroteHi! thanks for your answer, I install the xls extension... I wanna add this table of excel... If u can help me it could be very usefull.
Put this worksheet into same folder of your excel file.
When you open it you will get your table.
If you don't need excel file later, just copy the values of table.
And make a new variable named table, define it with that copied matrix.
After that, you can remove importData() function.
Worksheet1.sm (8,99 KiB) descargado 1533 vez(es).
