Help equation Solution
Help equation Solution - solve equation - Mensajes
#1 Publicado: 18/4/2020 7:24:19
Elton
Elton
0 me gusta en 3 mensajes.
I can't solve the equation below, I tried two options but none worked. Someone could help?
Elton Freitas
#2 Publicado: 18/4/2020 7:42:44
I can't solve the equation below, I tried two options but none worked. Someone could help ?
Please: attach the document for the missing data.
#3 Publicado: 18/4/2020 11:20:12
127 me gusta en 342 mensajes.
Let's start by observing that:
1) the "solve" function is native to smath but does not accept units of measurement (if you want to use it you must temporarily get rid of the units of measurement)
2) the "FindRoot" function you have defined relies on "solve" (see above)
3) in the "nonlinear Solver" plugin you will find a "FindRoot" function that can do for you and that manages the units of measurement
4) there are other features and plugins that can help you. I suggest you also consult Martin Kraska's Interactive SMath Handbook with lots of information and practical examples (you can find it in the tool you use to install plugins)
#4 Publicado: 18/4/2020 13:23:01
Elton
Elton
Yes. It is attached or attached.Modelo_Planilha de Calculos_OM_rev02.sm (2,2 MiB) descargado 1311 vez(es).
Thank you.
Best Regard.
Elton Freitas
#5 Publicado: 18/4/2020 14:11:13
haweHofmann
haweHofmann
3 me gusta en 32 mensajes.
a quadratic equation, solved algebraically?
MPa^2=((σ.solda)/(a.cordao))^(2)+3*((P.total)/(2*h*a.cordao))^(2)
sys(a.cordao≡-sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},a.cordao≡sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},2,1)
