1 páginas (4 elementos)
Clearing Variables for Re-use in same document - Mensajes
I'm using SMATH to bring in template calcualtions and substitute for hand calculations, but one thing I couldn't figure out is if it is possible to "clear" a variable so I can use the equation multiple times without carrying variables forward. I tried using the separator, but it doesn't clear variables.
Greetings,
In the 「Special Functions」 Plugin, you can get access to the function "Clear()". Here are (2) forum posts on topic to your question:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
- https://en.smath.com/forum/yaf_postst1576_clear---function.aspx
- https://en.smath.info/forum/yaf_postsm8183_Reset-Remove-Variable.aspx
WroteGreetings,
Many thanks. For my reference, and so people don't have to follow the links above, is just type Clear(variable1,variable2,etc)=1
Edit: Is there a way to clear all variables without specifying in the ()?
Custom Functions plugin has a set of ClearAll() functions.(See here)
sergio 20/3/2025 16:38:00
