Parallel Piping Hazen Williams
Parallel Piping Hazen Williams - mathcad to mathstudio - Mensajes
#1 Publicado: 22/3/2022 9:10:34
Erick Valentino
Erick Valentino
7 me gusta en 29 mensajes.
Hello! What's up
I would like to know how I can replace the "given" command from Mathcad to SmathStudio, I know that such a command does not exist in SMATH and for that there are other tools
I just need to find the flows Q1 Q2 and Q3 from a parallel pipe using the Hazen Williams equation, without having to do as many expressions
Thank you very much
Another question... I was thinking of making tutorial videos preferably using SMath Studio over any other software called Mathcad, MathCad Prime, Maple, Matlab, Matematica, etc.
Can the new paid version still use the plugins MAPLE, Cool Proops, Maxima, etc. for free? Or will they have to pay for it?
thank you very much, you are a very cool community
Tuberias en Paralelo Hazen Williams.sm (13,37 KiB) descargado 1281 vez(es).
Tuberias en Paralelo Hazen Williams.xmcd (26,7 KiB) descargado 1333 vez(es).
#2 Publicado: 22/3/2022 10:20:17
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Citar
You can use Mathcad Block region for this.
Click to enlarge
All my plugins will remain free.
Erick Valentino 22/3/2022 19:55:00, sergio 22/3/2022 17:33:00
#3 Publicado: 22/3/2022 15:26:58
Grupo: Moderator
AFAIK, roots() won't work with units.
You can use FindRoots() for that purpose.
Regards.
tuberias.sm (11,75 KiB) descargado 1311 vez(es).
Erick Valentino 22/3/2022 19:55:00, Вячеслав Мезенцев 22/3/2022 17:34:00
#4 Publicado: 22/3/2022 17:35:27
Grupo: Moderator
Or like this.
tuberias_uni.sm (12,14 KiB) descargado 1280 vez(es).
Erick Valentino 22/3/2022 19:55:00, overlord 22/3/2022 20:56:00
#5 Publicado: 22/3/2022 20:59:10
Grupo: Moderator
Or like this.
What the..? I didn't know you can use mathblock like this.
How FindRoot() can work under block with only one argument?
That is a very neat feature. Really appreciate you share this.
#6 Publicado: 23/3/2022 0:32:03
Grupo: Moderator
The first argument is implicitly substituted by the block itself. Then the function is called with two arguments.
Click to enlarge
#7 Publicado: 24/3/2022 9:00:06
Given/Find/Maximize/Minimize/Minerr/ODEsolve
1. Given/Find ... inspect Butler attached
2. Given/Minerr ... from iterative Smath code
In many instances superior to Minerr.
Given/ODEsolve from very many Smath ODE solvers.
Visit the code from Viacheslav [Uni]
Solve Given_Find [CO2_6179 Butler] Copy.sm (165,95 KiB) descargado 1081 vez(es).
#8 Publicado: 24/3/2022 14:25:53
Grupo: Moderator
Does mathcadblock could be used with al_nleqsolve() with this example?
And I think it would be nice if block can be inserted with command.
Not just from Insert menu, regards.
#9 Publicado: 24/3/2022 15:29:50
Grupo: Moderator
It can't be done directly. But in general it is possible. I can create generic functions Find and Minerr which can be customized to a specific function. Working with the Mathcad Block should be universal. The GNU Scientific Library has a number of functions for finding roots and minimizing. I want to first test the Mathcad Block on a set of different functions before offering a solution. Already existing solvers also need to be somehow connected in a universal way. Now I have not found a common approach to solve this problem as a whole.
1. One Dimensional Root-Finding
2. Multidimensional Root-Finding
3. One Dimensional Minimization
4. Multidimensional Minimization
sergio 25/3/2022 8:04:00
#10 Publicado: 24/3/2022 15:41:17
Grupo: Moderator
I can add a keyboard shortcut. What about [Ctrl]+[Shift]+[B] ?
#11 Publicado: 24/3/2022 15:57:55
Grupo: Moderator
Unfortunately GNU Scientific Library doesn't work with mono, so it is not usable under Linux.
I don't want to be rude but why it is called Mathcad Block?
MathBlock would suits it more, just a suggestion.
#12 Publicado: 24/3/2022 16:09:40
Grupo: Moderator
It is located in the Mathcad Toolbox plugin and was created to repeat the generalized ODE solver from Mathcad. This is made for the future for the converter. I hope that someday the converter from Mathcad will be finalized and there should be unambiguous equivalents for it. Therefore, I try to fill the Mathcad Toolbox plugin with similar functions. There are many interesting documents and it would be great if they were completely converted. It would also make it easier to transfer documents and users
I specifically set this name so that it does not interfere with the appearance of another similar block. Perhaps, after using the block, an understanding will come of how to make it a more convenient. For this case we will reserve this name (MathBlock).
